Engine makes squeak noise
- Gdodson
- Visitor
24 Aug 2013 13:50 #80917
by Gdodson
Engine makes squeak noise was created by Gdodson
Hi guys/gals everytime i turn my suzuki jimny on the engine makes a squeak noise but it only makes a noise when the engine is cool. once its warmed up or has been in the sunshine its fine doesnt make a squeak.
Its now done 56000 and im not sure if its ever had a cambelt/ timing belt change do u think this could be a sign it needs replacing or am i just worrying ??
Thanks glenn
Thanks glenn
- GuardianAngel
- Visitor
24 Aug 2013 14:08 #80919
by GuardianAngel
Replied by GuardianAngel on topic Re:Engine makes squeak noise
Could be an alternator belt slipping. Wont be a timing belt as either you have an M13A engine with a timing chain, or an earlier one with a belt but the engine wouldn't be running if it was slipping!
- Gdodson
- Visitor
24 Aug 2013 14:22 #80921
by Gdodson
Replied by Gdodson on topic Re:Engine makes squeak noise
Does this mean i need to get the alternator belt replaced? i dont think the timing belt is a chain i have an 03 o2 soft top.
or does it just need tightening somehow
Cheers Glenn
Cheers Glenn
- markyp2000
- Visitor
24 Aug 2013 14:38 #80923
by markyp2000
Replied by markyp2000 on topic Re:Engine makes squeak noise
Tighten it up there should be a bolt with an elongated slot slaken the bolt off and leaver it out
24 Aug 2013 18:34 #80942
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Re:Engine makes squeak noise
Timing belt should be done at 60k I think, get it done and your other belts too. Peace of mind then. Easy to do diy too
Grey pick up Jimny
Time to create page: 0.135 seconds
