1st day off road Slindon
  • Poyner111
  • Visitor
  • Visitor
04 Aug 2013 07:52 #78913 by Poyner111
Replied by Poyner111 on topic 1st day off road Slindon
There are 2 M10 socket button heads holding the number plate on, i planned to replace them with M10 stainless A4 eye bolts and A4 shackle.
The ali plate is bolted to a 10mm steel plate in tern bolted direct to the front chassis....hoping that will be ok to get me out of trouble ?
  • Poyner111
  • Visitor
  • Visitor
06 Aug 2013 09:47 #79176 by Poyner111
Been doing a little research before i add recovery eye bolts......umm turns out they are nowhere near good enough, M10 only rated for 250kg!! no idea what the shear of an M8 bolt is that is holding the plate to the chassis.
seems like the forum is a little light on info......hints at the front of the chassis not suitable to fix to?
any one got a suggestion as to where they can be bolted ? what forces you can expect when pulling out of mud ? I currently have a 5 ton strop, 3 ton shackle and ........... ( now not decided) to bolt to chassis will 3 ton do or is that underestimating
  • barnes
  • Visitor
  • Visitor
06 Aug 2013 11:33 #79185 by barnes
Replied by barnes on topic 1st day off road Slindon
Many people use a bridle strop across the two chassis rails with ora recovery points that way you spread the weight
  • TonyAlewis
  • Visitor
  • Visitor
12 Aug 2013 02:51 #79640 by TonyAlewis
Replied by TonyAlewis on topic 1st day off road Slindon
Everybody knows that the Polar Bears eat them.
  • Sponnie
  • Visitor
  • Visitor
12 Aug 2013 07:23 #79643 by Sponnie
Replied by Sponnie on topic Re:1st day off road Slindon
Ha ha you have certainly got your penguin posts mixed up TonyAlewis! He he
Sent from my GT-I9300 using Tapatalk 4
Time to create page: 0.148 seconds
