Gaz's reasonably priced jimny..
- gaz3359
- Visitor
20 Feb 2013 19:40 - 20 Feb 2013 19:41 #63401
by gaz3359
Replied by gaz3359 on topic Gaz's jimny on a shoe string
few updates
bought this for a home made snorkel havnt made a start yet but its there anyway
Diff oil's i knew the front needed changing when i checked the level but didnt think it was going to be as bad as this
half a pint of clean water came out before this mess,i filled the diff with clean engine oil and went for a lap around the block in 4wd dropped that which cleaned it out then refilled with correct oil diff much quieter.did the rear aswell although that was quite clean.
My mate managed to fab me some bits for recovery points,pretty simple really used box section the slid into the chassis rails and then a piece of 6mm plate with holes in the end for shackels.simple but effective,after a bit of grinding drilling tweaking and paint there all fitted.should have got more photos but my phone is on the blink at mo and the camera works when it wants.
17th feb had a pop up pea farm with a couple of pals,didnt take the jim,went in the sj which ive just helped me mate convert from a 1.3 carb to a spi 1.6 out of a vit goes well,also me mate with a fourtrak that has just been built out of 3 trucks,that thing is huge.couple of pics
had a pop up cleadon hills the other day to walk the dog and thought id try out a bit of twist,more than please with the angle for a cheap spring spacer lift kit arb removed and extended hoses,had to trim a bit more arch liner out after,although i had them nie on spot on.chuffed
Painted the recovery points white so you can see them so you dont give yourself a dead knee also started my wood floor in the boot got this to finish in the morn but should look like this done.friday im doing my breathers for the diffs and gearbox and also changing the gearbox oil and trans box oil cheers again !
Last edit: 20 Feb 2013 19:41 by gaz3359.
- Dan_w
- Visitor
20 Feb 2013 23:48 #63478
by Dan_w
Replied by Dan_w on topic Gaz's jimny on a shoe string
Looking great Gaz, its comming along great guns, I like the recovery points
That mess looks exactly the same as what came out of my diffs when I changed my oil
- adamjimny
- Visitor
21 Feb 2013 05:29 - 21 Feb 2013 05:33 #63483
by adamjimny
Replied by adamjimny on topic Gaz's jimny on a shoe string
i must admit that is looking very very nice it all goes well together
Last edit: 21 Feb 2013 05:33 by adamjimny.
- gaz3359
- Visitor
21 Feb 2013 08:33 #63488
by gaz3359
cheers guys im more than happy with how its turning out now better than i thought especially concidering im still trying to keep the spending to a minimum.
- stevenb
- Visitor
21 Feb 2013 13:22 #63499
by stevenb
Replied by stevenb on topic Gaz's jimny on a shoe string
lcomeing along very nicley budy ,how anoying was it to do the power steering and alt belt
mine,s wineing like hek so need to get them done .
- gaz3359
- Visitor
21 Feb 2013 21:57 #63572
by gaz3359
there not too bad just a bit fiddley as there isnt alot of room plus i have hands like shovels so that doesnt dont help lol
Time to create page: 0.193 seconds
