Gaz's reasonably priced jimny..
- gaz3359
- Visitor
06 Feb 2013 10:41 #61082
by gaz3359
Replied by gaz3359 on topic Gaz's jimny on a shoe string
Few updates havnt used the jim since 2 weekends ago i had a knocking from the rear turns out the rear brake shoe pins had gave up causing all sorts of noises so while i was waiting for the new kit to turn up i thought id do a few other bits and bobs while it was in the garage
id ordered a cheapy lift kit from ebay got this fitted along with my new wheels with 195 80 15 sharas on 7j mods and i also fitted 32mm spacers well happy with the results wider and taller
9" of diff clearance not bad for beign done on a buget
also ordered a few small service bits as im guessing it hasnt been done for a while judging by the rest of the car
knackered plugs could fit flat head in that gap
gave the throttle body a clean
changed the alt and power steering belts as they were noisey and all cracked not much room for a little engine
Had a small shovel lying about in the garage for a while fitted that to the inside of the back door
While i was still waiting for the fitting kit for my rear shoes my dad suggested having a go at making the prima strip dissapear,when i bought this the preivious owner had wedged it in a barbed wire fence some how and there was alot of dints and deep scratches,i could have put the jimny into the bodyshop next door to the garage i work at and they could have sorted it and painted the side up but been on a budget and with the rest of it not been mint thought me and me dad would have a go in total the materials cost me about 30 quid its by no means perfect and upclose the paint is a slightly darker shade but couple of feet back it looks better than a gery stripe,also if i scratch it off road i wont be bothered,also once the weather is a tad better i will polish it back with the polisher.
and a couple after pulling it out the garage
its good side lol
still a fair bit to do,got some extended hoses to go on
going to do my diff breathers with hose pipe this week,ordered some pipe to have a go at a buget home made snorkel also check the transmission oils and levels.still awaiting my fabbd recovery points.thanks for looking more pics updates to follow cheers
its good side lol
- Tadpole
- Visitor
06 Feb 2013 10:49 #61084
by Tadpole
Replied by Tadpole on topic Gaz's jimny on a shoe string
This is turning into a tidy Jimny, all credit to you for doing the work on a buget Gaz ......................
- Dan_w
- Visitor
06 Feb 2013 17:40 #61141
by Dan_w
Replied by Dan_w on topic Gaz's jimny on a shoe string
Looking great mate, have you tried using a buffer on the side you painted, you may be able to get a better blend of he paint with a good buff. I used rattle cans on a repair on a previous car and the match was not great, after a rubdown with 1200 grit paper and a good polish with a buffer it looked much better.
- renard38
- Visitor
06 Feb 2013 18:11 #61144
by renard38
Replied by renard38 on topic Gaz's jimny on a shoe string
good job! nice color
- GuardianAngel
- Visitor
06 Feb 2013 18:29 #61147
by GuardianAngel
Replied by GuardianAngel on topic Re: Gaz's jimny on a shoe string
Nice work
Word of warning. If your changing your extended hoses, expect your union nuts to be rusted up. As a result, you may have to hacksaw the brake lines and build new ones :pinch:
I know from bitter experience this weekend just gone
- iloveics
- Visitor
06 Feb 2013 18:54 #61150
by iloveics
Replied by iloveics on topic Gaz's jimny on a shoe string
Nice work! how on earth have you got 9 inches of ground clearance!!!
according to a tyre size tool, total size of yours is 693mm and my tyres (215/75r15) are 703mm, but i have exactly 8 inches off diff clearance!!
maybe its the chunky tread?
Time to create page: 0.160 seconds
