Finally getting somewhere :-)
- TomDK
15 Dec 2012 16:15 - 15 Dec 2012 16:44 #55574
by TomDK
Finally getting somewhere :-) was created by TomDK
2003 Jimny O2
OME 2" suspension lift
4.16:1 rocklobster Transferbox
Rockwatt Transfer Cradle
Castor Correcting bushes
ORA HD Winchbumper, Soon to be modded for Warn 8274 winch.
235-75-15 Insa Turbo Special Track tyres
Dyneema 10mm winch rope
Exide AGM 800 CCA Battery, one more soon
Things to come, when I have money:
Defender Extended wheel arches
OMP 6-point internal cage
OMP seat and 4-point harness
new rims with wider offset
ORA axle trusses
Started fitting the 8274 in the ORA HD bumper. It's not a direct fit (obviously
) So some cutting needed. Welding some new reinforcements to the bumper once the installation is done.
Also needed to cut the front crossmember of the body. Will weld a new one on closer to the radiator once the winch is completely installed.
And also need to cut the bonnet a bit
Next thing is OMP internal cage and LR Extended arches.
and then to decide. Either a Gigglepin twin adventure top or a cheaper solution. Swap the Warn XP motor for the new 9HP Bowmotor 3
Of course, both options require the uprated mainshaft.
ORA axle trusses
Last edit: 15 Dec 2012 16:44 by TomDK.
- nicho
15 Dec 2012 16:42 #55575
by nicho
Replied by nicho on topic Finally getting somewhere :-)
i like this
- Tadpole
15 Dec 2012 20:30 #55587
by Tadpole
Replied by Tadpole on topic Finally getting somewhere :-)
:ohmy: nice work, this is coming along well love it ......
- Dan_w
16 Dec 2012 18:30 #55624
by Dan_w
Replied by Dan_w on topic Finally getting somewhere :-)
Looks great, mate
- TomDK
16 Dec 2012 19:07 #55626
by TomDK
Replied by TomDK on topic Finally getting somewhere :-)
Thanks guys
Hope to have the front and winch done in a few days.
Must admit though.. The arches looks a bit sad without the plastic flares
Time to create page: 0.088 seconds
