Aussie jimny
  • adamatdraycott
  • Visitor
  • Visitor
22 May 2012 06:35 #40924 by adamatdraycott
Replied by adamatdraycott on topic Re: Aussie jimny
That twin cab looks really nice!
  • 31zook
  • Visitor
  • Visitor
06 Jul 2012 09:20 #43591 by 31zook
Replied by 31zook on topic Re: Aussie jimny
starting on my 3link. 16inch's of travel, but ill be limiting it to 10 or so so that i don't have shocks through the bonnet. 50mm bump stop spacing for a 31" tyre, but i can see the head light bucket going on a diet soon :cheer:
  • 31zook
  • Visitor
  • Visitor
20 Sep 2012 10:37 #48420 by 31zook
Replied by 31zook on topic Aussie jimny
Been up and running for a few months now, managed to keep 14" of travel in it and still drive it to work and back everyday.
  • Paul4x4
  • Visitor
  • Visitor
20 Sep 2012 13:09 #48424 by Paul4x4
Replied by Paul4x4 on topic Aussie jimny
There's some nice flex going on! Good job! B)
  • renard38
  • Visitor
  • Visitor
20 Sep 2012 18:17 #48428 by renard38
Replied by renard38 on topic Aussie jimny
beautifull pictures B)
  • panosd
  • Visitor
  • Visitor
21 Sep 2012 13:57 #48469 by panosd
Replied by panosd on topic Aussie jimny
Your 3 link is :evil: . Are you going to make also at rear?
Very good job. Some more picks of the susp set up?
With what t-case do you run 31'' . 4.1 or 5.1 ?
  • 31zook
  • Visitor
  • Visitor
22 Sep 2012 20:48 #48568 by 31zook
panosd wrote: Your 3 link is :evil: . Are you going to make also at rear?
The rear end is a misstery, maybe rover trailing arms will be swapped in, or an X-link or I mod the tank in a big way and 3-link the rear end... I guess I'll sort it out if I ever get there...
The coil bucket had to be moved forward 50mm as the cycle changed it enough to miss the bump stop completely. And you can see the lower links have a 40° bend in them and go over the top of the tie rod.
This is on the passengers chassis rail
This is the top link of the diff
Gearing is currently 4.16 on 30s but I have chromo CVs coming and hoping to put in 5.14 in as my final gearing set up.
  • panosd
  • Visitor
  • Visitor
23 Sep 2012 10:32 - 23 Sep 2012 10:40 #48584 by panosd
Also at rear you can do 3 link. You wont have any problem with the tank. When you try to do 4 link at rear
you have problems with the tank.
A friend of mine did his jimny 3 link at rear and had no issues with the tank.
He used the original radius arm bases on tha chassis. I am waiting to start on mine.
Take a look.
He has 4'' suspension lift, 3cm body, 6.5 t-case, front+rear arbs, front+rear HD axleshafts and CV's, silverstone xtreme 31/10.5/15.
Last edit: 23 Sep 2012 10:40 by panosd.
  • markyp2000
  • Visitor
  • Visitor
23 Sep 2012 11:42 #48590 by markyp2000
Replied by markyp2000 on topic Aussie jimny
dont wanna sound thick but what is the point/advantages of 3 link stuff
  • TomDK
  • Visitor
  • Visitor
23 Sep 2012 12:06 #48593 by TomDK
Replied by TomDK on topic Aussie jimny
Better articulation and axle won't rotate when it articulates.
At least, that's my guess.
  • panosd
  • Visitor
  • Visitor
23 Sep 2012 14:06 #48597 by panosd
TomDK wrote: Better articulation and axle won't rotate when it articulates.
I think pics speak by themselves. B)
  • Smoggy
  • Visitor
  • Visitor
23 Sep 2012 14:27 #48598 by Smoggy
Replied by Smoggy on topic Aussie jimny
Hey panosd do you have any more detailed pics of how the 3link setup connects to the rear axle. I'm very interested Cheers.
