My Jimny from the Netherlands
  • w0ut69
  • Visitor
  • Visitor
21 Jan 2012 09:40 - 21 Jan 2012 10:12 #31458 by w0ut69
Replied by w0ut69 on topic Re: My Jimny from the Netherlands
Ok, about the front shock that's something I had not thought about but the new bushes are very thick and still I can't get the nut on the extension :P
But the rear suspension was pretty easy I jacked the axle up and I remove the bolt. Then I let the axle get down and remove the spring. Then it was easy, put the spacer in place and mount the extension on the shock with bushes between. I pulled out the shock and put the bolt back in. B)
Now I know it for the next time. :woohoo:
Thanks!
Last edit: 21 Jan 2012 10:12 by w0ut69.
21 Jan 2012 12:07 #31475 by dirtydogz
If I was fitting the front shock extension, I think it might have been easier to cut 4 or 5 mm off one of the bushes.
But looking at the photo of the front shock bushes they look ok to me.B)
2002 JLX Soft Top B)
Jimnybits 2" lift +Pro Comp ES1000 shocks.:) Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
  • w0ut69
  • Visitor
  • Visitor
21 Jan 2012 12:18 - 21 Jan 2012 12:19 #31478 by w0ut69
To cut a few mm of the bushes was maybe better and easier, but I thought they come specialy for the Jimny so they will fit. The job is done but it cost me 6 hours! :ohmy:
A question, I want black rims! Is it easy to paint them self? Or do someone knows where I can order black rims and that they send to the Netherlands?
Last edit: 21 Jan 2012 12:19 by w0ut69.
21 Jan 2012 12:51 - 21 Jan 2012 13:01 #31484 by dirtydogz
Looking at your rims they are in good condition so save your money and spray them black, as you will be a able to fit 205 or215/75 /15 m/t or a/t tyres on the standard rims.:P
You will need to trim the front bumper a little as it's a mk 2 facelift and the tyres will rub on full lock.:angry:
Last edit: 21 Jan 2012 13:01 by dirtydogz.
  • w0ut69
  • Visitor
  • Visitor
21 Jan 2012 18:16 - 21 Jan 2012 18:19 #31501 by w0ut69
Do I need to trim my front bumper when I fit 205/75/15? I tought only by 215's.
Wich tyres do you have Dirtydogz?
Last edit: 21 Jan 2012 18:19 by w0ut69.
21 Jan 2012 21:09 #31516 by dirtydogz
Iv'e got 205/75/15 maxxis M/T on 7x15 black modulars but my jimny is a MK1 with the smaller bumper, and 2" jimnybits spring lift.
Attachment DSCF1641_2012-01-21.JPG not found
Time to create page: 0.168 seconds
