My Jimny from the Netherlands
www.bits4vits.co.uk/springspacerinstructions.pdf
2002 JLX Soft Top
Jimnybits 2" lift +Pro Comp ES1000 shocks. Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
- w0ut69
- Visitor
But now I thought, when you fit wheel spacers and I drive about bumps and so forth. Will it fit in the wheel chamber? Does it not damaged the bodywork? Maybe a stupid question!?
- darthloachie
- Visitor
w0ut69 wrote: I received my wheel spacers and suspension spacer kit. I will fit them next Saturday! :woohoo:
you will be fine
- w0ut69
- Visitor
Thanks
- w0ut69
- Visitor
This is how I started, my Jimny how it was.
It was a hell to get the spring out off it, here is where I was fitting the spring spacer kit.
Everything in place, It was very difficult to fit the nut on top of the shock. I used a big bar to jack the shock up, then my brother put the nut in place.
Front finished with wheel spacers.
Left side finished, I used the bushes from my front shock and saw him by two.
Both sides ready.
Fitted the wheels, ready with wheel spacers 32mm Grayston's.
And a picture from the rear.
After all, it was the first time that I did something with the suspension, but I'm glad that it's finished.
The rear was pretty easy but the front was very difficult because it was hard to get the spring off and to fit the nut on top of the shock. My next step will be bigger tyres and black rims.
Next time, it would be easier if you fit the top of the shock on first, and pull the shock out to fix on to the axle end like at the rear when the wheels are back on and been lowered back on the ground. .
2002 JLX Soft Top
- w0ut69
- Visitor
But the rear suspension was pretty easy I jacked the axle up and I remove the bolt. Then I let the axle get down and remove the spring. Then it was easy, put the spacer in place and mount the extension on the shock with bushes between. I pulled out the shock and put the bolt back in.
Now I know it for the next time. :woohoo:
Thanks!
But looking at the photo of the front shock bushes they look ok to me.
2002 JLX Soft Top
- w0ut69
- Visitor
A question, I want black rims! Is it easy to paint them self? Or do someone knows where I can order black rims and that they send to the Netherlands?
You will need to trim the front bumper a little as it's a mk 2 facelift and the tyres will rub on full lock.
2002 JLX Soft Top
- w0ut69
- Visitor
Wich tyres do you have Dirtydogz?
Attachment DSCF1641_2012-01-21.JPG not found
2002 JLX Soft Top
