Garry's Competition Tray Back Jimny
  • Sponnie
29 Jan 2013 22:54 #60208 by Sponnie
Replied by Sponnie on topic Re: Re: Garry's Competition Tray Back Jimny
Smoggy wrote:
Sponnie wrote: Copied from the 'show us your flex' topic
thanks for that,the spec could be a bit long winded but theres not much i havent tweeked or changed!!
here goes :
2.5 v6 auto from a gv,
pair of oddessy pc1500's,
8274 with gp +3"drum+air freespool,gp h/d main shaft,+25%gears xp motor .
rear winch warn xp with 8274 motor and modified rope retention system.
suspension arms kap h/d with polybushes all round,
front arms extended 40mm,
front axle is a modified sammy casing with chromoly 4340 shafts and cv's, modded arb to suit sammy shafts,
diff is jimny ,
rear axle is standard apart from arb and rear disc conversion.
lowered rear top shock mounts and raised lower mounts (big jimny ones)custom rear winch tray with 2 swivel recovery points and ali tool box fitted behind under spare wheel.
kap h/d panhard rod in rear,front one custom made (as i bent a h/d kap one).to rig up the jimny steering to the sammy axle i swapped the stub axle carriers left for right and right for left to put the part that the steering link bar rod ends go into behind the axle instead of in front, i then custom made a bracket to bolt on with the nearside caliper carrier to form an arm coming forward from the stub axle carrier to allow the jimny steering bar to connect to.inside is an arb h/d compresser and 1 gallon air tank to keep the 2 arb's and air freespool working nice. the rear tray holds 4 waffle boards,ground anchor(steel pin type for hard ground and hammer) ground anchor plough type,wheel brace,radiator/tranny cooler cooled by thermo controlled kenlowe fan. snorkel is ali linked to std airbox(sealed of course).
lights are 2 rear,2 rearside,2 front side,2 front spotsand 2 front fogs +headlights.bonnet is chequerplated in ali,as is the belly guard and front bash plate. i think thats everything!!! i cant take credit for cutting the cab down that was down to darren at kap who as you can see did a crackin job i got it back with just 2 chassis legs stickin out the back.all the rest of the work was done by myself.
Sent from my GT-I9300 using Tapatalk 2
Sponnie, Ive got the axles, panhards, steering bar and wheels and tyres from this car now. Gary now has uprated Landy items and even bigger shocks and lift!
I know, because I rang the guy when they were for sale and you had beat me to them!! Lol.
Sent from my Nexus 7
  • Mister Stu
24 Mar 2013 13:26 #66756 by Mister Stu
Replied by Mister Stu on topic Re: Re: Garry's Competition Tray Back Jimny
Dude this trayback is awsome B) Are you local to the southwest?
  • Smoggy
24 Mar 2013 15:18 #66767 by Smoggy
Replied by Smoggy on topic Garry's Competition Tray Back Jimny
No he is from County Durham in northeast.
  • Mister Stu
24 Mar 2013 21:29 #66810 by Mister Stu
Replied by Mister Stu on topic Garry's Competition Tray Back Jimny
Couldnt get much further in the other direction :P just when he said about the de-cider in Saltash and assumed he was localish :silly: :silly:
  • Bren998
28 Mar 2013 12:19 #67136 by Bren998
Replied by Bren998 on topic Garry's Competition Tray Back Jimny
A few photos from the Muddy truckers trophy 2013 from last weekend.
12 Apr 2013 21:15 #68584 by kirkynut
Where did you come in the Muddy Truckers mate???
My mate Kev (KK) came 6th in his 90.
I'd love to come and take photographs and write an event report for this but it's just so flipping far from me in Essex!
Time to create page: 0.211 seconds
