New Jimny(at least new to me)
  • gazert
01 Feb 2011 12:12 #10759 by gazert
Replied by gazert on topic Re:New Jimny(at least new to me)
maverick wrote: All you need now is some 16" GV Rims .... and a Lockrite in the rear axle...
And that lift it will 'settle-down' once you've been out a few times!!
16" with 31" special tracks are on the shopping list as well as a Lockrite!
The lift has settled somewhat since it went on. The body lift has made it seem a lot taler than just the lift kit.
I am well chuffed with her road manners to be honest it doesn't handle much worse than when she was on +2 spacers.
Still cruises at 60 plus with no weave or wobble, I think for peace of mind i am going to pt steering damper on.
  • gazert
01 Feb 2011 12:15 #10760 by gazert
darthloachie wrote: so thats what +7 looks like :woohoo:
just wait untill you have 31s on that'll be another inch of lift
do you need oxygen at those heights? :unsure:
When i fitted the KL71 i measured them at 29" and a mate has 10.5 x 15 x 31" special tracks on a Landy (sorry for swearing). They measure just under 32.5"
I may get another 2-3" Lift!
  • darthloachie
01 Feb 2011 12:25 - 01 Feb 2011 12:28 #10761 by darthloachie
Replied by darthloachie on topic Re:New Jimny(at least new to me)
Might be wrong but you'll only get half that as axle lift :unsure:
oh and you'll need a rocklobster as well :evil:
Last edit: 01 Feb 2011 12:28 by darthloachie.
  • gazert
01 Feb 2011 13:03 #10763 by gazert
aint i thick!!! ur right maybe 1-1.5" lol
The vvt pushy button has a lower final drive ratio than the others by a bit so i am hoping 31's will be ok'ish.
  • Delvederis
01 Feb 2011 13:49 - 01 Feb 2011 13:50 #10765 by Delvederis
Replied by Delvederis on topic Re: New Jimny(at least new to me)
Very nice ride. Great looking.
For the 31'' you will need to change the gears of our transfer or you will have to remove the button 4x4 system and instale a t-case with 5.14 gears.
The same mod was made from a friend of mine before 3 years and he still has it working like this, but with
toyota land cruiser 70 axles.:evil: .
For lift more than 3'' caster kit doesn't affect right,and you need to fit caster radius arms.
I had caster kit with 4,5'' and changed it with caster radious arms for 4'' lift.
Also to avoid roll over you should change your front and rear bump stops with a set of longer.
Don't forget that,very important.
And last for every inch lift you get the half of it width must get to the wheels,so you can have good stability on road.
Last edit: 01 Feb 2011 13:50 by Delvederis.
  • gazert
01 Feb 2011 14:25 #10767 by gazert
Replied by gazert on topic Re: New Jimny(at least new to me)
Thanks for the tips.
I am trying to sort longer bump stops.
Time to create page: 1.001 seconds
