Halfords Dog-Taxi
  • barnes
29 Aug 2013 18:11 #81490 by barnes
Replied by barnes on topic Halfords Dog-Taxi
Halford wrote: :ohmy: busted
you can never have too many anchoring points when out playing
Gave me terrific flash backs of the documentary that was on c4 about dogging :sick:
  • JivingDaddy
01 Sep 2013 08:08 #81774 by JivingDaddy
Replied by JivingDaddy on topic Halfords Dog-Taxi
Halford's Missus?!
Dogging
  • jonesyba420
01 Sep 2013 09:20 #81776 by jonesyba420
Replied by jonesyba420 on topic Re: Halfords Dog-Taxi
Halford wrote: Hi zaine
There's a cable with 4 pin connector taped to the wiring harness behind the left hand side rear trim panel, removing the tape gives you about 6 inches of cable play - I simply cut off the connector and attached the speaker cables using blue bullet/socket crimps, it's easy to figure out which cables go where, i.e. black stripe to black stripe - very easy novice DIY job.
Don't forget to "rip-off" the foam from behind the speaker grilles on the rear panels - to let the sound out.
for rear panel removal see here
s227.photobucket.com/albums/dd170/bishop...y%20rear%20speakers/ the password is: suzuki_jimny
does anyone know if all this applies to a 2002 hardtop?
13 Sep 2013 19:41 #83080 by Halford
decided to redo the rear space of the DogTaxi
found Wickes 3pk chipboard loft storage interlocking panels ideal @ only £6.98
320mm wide x 1220mm long x 18mm thick
2 of the boards are cut at 910mm wide
the board nearest the rear door needs radiused corners of 50mm, which just happend to be the size of a 500g coffee mate tub
the panel nearest the seats looks as below
and put them all together
that's the base done, just need to lock the panels together then make a removable tool storage box on the right, will update with the next steps soon
  • Tadpole
13 Sep 2013 19:53 #83083 by Tadpole
Replied by Tadpole on topic Halfords Dog-Taxi
Looking good Halford very professional ................. ;)
  • steffan
13 Sep 2013 20:44 #83086 by steffan
Replied by steffan on topic Halfords Dog-Taxi
Halford wrote: decided to redo the rear space of the DogTaxi
Don't forget to pva glue the joints or if thay get WET that's where they will rot it will also help stop them from comeing apart
