toph's jimny...new suspension set up.
  • mcjimny
25 Apr 2011 19:27 #15502 by mcjimny
Replied by mcjimny on topic Re: toph's jimny...new suspension set up.
Thats a smart set up. Some great ideas on there, he could easily make those for sale. Its essentially like the landy boys do with the tubular shock towers if i work it out right from the pictures?
Whats the total lift you've achieved?
  • toph
25 Apr 2011 19:28 - 02 Nov 2012 00:40 #15503 by toph
Cocopolo wrote: REALLY nice flex!
... your radius arms mounts are above the axle and not below ... wow ... never seen a mod like this ...
my bottom damper mounts are raised, radius arm mounts on the top of the axle now.
Last edit: 02 Nov 2012 00:40 by toph.
  • toph
25 Apr 2011 19:43 - 13 Sep 2012 15:03 #15504 by toph
mcjimny wrote: Thats a smart set up. Some great ideas on there, he could easily make those for sale. Its essentially like the landy boys do with the tubular shock towers if i work it out right from the pictures?
The only reason for the towers is because of the relocation of the bottom mounts, I would have lost alot of travel so had to make that back up by also raising the tops. So much so the body of the damper was longer than the available space after moving the bottom mount.
Aim for this project wasn't for lift, was all about clearing under the axle to stop those stupid standard mounts from snagging and gaining as much articulation as possible without going silly and it not being a Jimny any more.
Height wise its about 4 inches lift, i havent really measured it, rock slders are about 18" from the floor(kneecap height)
Measuring off the damper there is now 4" compression and 6" extension, which at the end of the axle(wheel) with the rotation from the drop is somewhere in the region of 9" extension.
Last edit: 13 Sep 2012 15:03 by toph. Reason: more weird symbols in the text
  • Cocopolo
25 Apr 2011 20:55 #15505 by Cocopolo
Replied by Cocopolo on topic Re: toph's jimny...new suspension set up.
my bottom damper mounts are raised, not radius arm mounts
Sure they are not changed? I mean: my front arms are placed under the front axle ... but in your picture i clearly see that the arms are placed above the axle tube ...
  • toph
26 Apr 2011 05:26 - 06 May 2011 23:00 #15508 by toph
sorry I though you meant I had changed the actual mouting bracket,
Last edit: 06 May 2011 23:00 by toph.
  • darthloachie
26 Apr 2011 06:06 #15509 by darthloachie
Replied by darthloachie on topic Re: toph's jimny...new suspension set up.
nice B)
Time to create page: 0.659 seconds
