toph's jimny...new suspension set up.
  • toph
24 Apr 2011 20:34 - 02 Nov 2012 00:44 #15437 by toph
Been a lot of work going on for the last month changing the damper mounts on the chassis and axle. This week all the mounting, welding and testing was completed, I now have a completely clean axle clearance. Green laning and pay&play tomorrow :cheer:
This one doesn't do it justice bad camera angle
Last edit: 02 Nov 2012 00:44 by toph.
  • bertbuckie
25 Apr 2011 06:28 #15445 by bertbuckie
Replied by bertbuckie on topic Re: toph's jimny...new suspension set up.
:D - where do you live? ( and park up at nights lol )
what suspension setup is that ?
  • renard38
25 Apr 2011 07:13 #15448 by renard38
Replied by renard38 on topic Re: toph's jimny...new suspension set up.
very good flex :woohoo:
  • mcjimny
25 Apr 2011 09:15 #15459 by mcjimny
Replied by mcjimny on topic Re: toph's jimny...new suspension set up.
Lovely truck one of the nicest i've seen! Some proper flex going on and some great mods.
We need more pics and a full spec, these are just teasing us:laugh:
  • toph
25 Apr 2011 18:48 - 02 Nov 2012 00:59 #15498 by toph
Not long got in after a lonnnng day out, 8am start had a rough time with a knacked bush on the push rod so was fighting the steering on the road, basically "death wobble" which i hadn't noticed before going out.
suspension set up is "home made" have a friend who is a good fabi, so the new damper towers are 6mm steel, the original bottom mounts removed and new platforms made that mount level with the axle.
pictures speak a thousand words so will post them up and not bore you with the crap descriptions i keep typing and deleting.
scruffy at the minute
6mm welded both sides of each seam
flash photography makes every thing look shitty! (must sort those banana springs one days also!)
[strike]
Not got any pictures of the bottom mount setup, will get some this week.[/strike]
Last edit: 02 Nov 2012 00:59 by toph. Reason: images rehosted
  • Cocopolo
25 Apr 2011 19:19 #15501 by Cocopolo
Replied by Cocopolo on topic Re: toph's jimny...new suspension set up.
REALLY nice flex!
1) which springs are you using?
2) ... your radius arms mounts are above the axle and not below ... wow ... never seen a mod like this ...
Time to create page: 0.173 seconds
