Run wires from engine compartment into cabin?
  • distantcamera
15 years 10 months ago #9698 by distantcamera
Run wires from engine compartment into cabin? was created by distantcamera
Hi Folks,
Can anyone tell me the easiest way to run wires from inside the engine compartment to the inside of the cabin? Hopefully there is a way that doesn't involve drilling or encouraging water into my cabin :)
Cheers in advance for any advice!
  • JonathonMarshall
15 years 10 months ago #9700 by JonathonMarshall
Replied by JonathonMarshall on topic Re: Run wires from engine compartment into cabin?
There is an ideal place in the passenger footwell. If you pull the mat back and look in the centre, towards the top you will see a wire going through towardds the centre console. Try get something in that grommet which will allow you to pull your wires through. I taped mine to the screwdrive in the image. It pops out near the brake lines to the left of the passenger wheelarch in the engine bay.
Attachment S7002456.JPG not found
Attachment S7002454.JPG not found
  • lukeyblunt
15 years 10 months ago #9703 by lukeyblunt
Replied by lukeyblunt on topic Re: Run wires from engine compartment into cabin?
Thanks! That answers one of my many questions!
Regarding rooflights.. i would appreciate any help on the link below :)
www.bigjimny.com/index.php?option=com_ku...=6&id=9695&Itemid=75
Cheers lads !!
  • Delvederis
15 years 10 months ago #9705 by Delvederis
Replied by Delvederis on topic Re: Run wires from engine compartment into cabin?
Also there is another hole with rubber cap that is at the uper right place of the engine apartment. Its right behind the abs sensor.
From tha hole i passed the arb cables for the buttons.
  • JonathonMarshall
15 years 10 months ago #9709 by JonathonMarshall
lukeyblunt wrote: Thanks! That answers one of my many questions!
Cheers lads !!
I'm following that with interest. I'd like to know how to get the wires neatly back into the car. I have a feeling I may be able to drill a hole throught the roof, where the roof bars (not rails) mount, therefore covering the hole to the elements etc
  • distantcamera
15 years 10 months ago #9720 by distantcamera
Replied by distantcamera on topic Re: Run wires from engine compartment into cabin?
JonathonMarshall wrote: There is an ideal place in the passenger footwell. If you pull the mat back and look in the centre, towards the top you will see a wire going through towardds the centre console. Try get something in that grommet which will allow you to pull your wires through. I taped mine to the screwdrive in the image. It pops out near the brake lines to the left of the passenger wheelarch in the engine bay.
Many thanks! That looks perfect for the job.
Time to create page: 0.105 seconds
