slight grease leaking from ball joint
08 Jul 2009 15:21 #977
Replied by mlines on topic Re:slight grease leaking from ball joint
I do the kingpin bearings and axle oil seal. I don't do the swivel seal or felt rings, these are only available from the dealer. In practice I have always found the swivel seal and felt ring cleans up ok anyway and doesn't need changing.
If you really have difficulty getting the swivel seal and felt ring then I can get them for you as my dealer is local, but this won't be at a discount
- jonplace
08 Jul 2009 19:08 #978
by jonplace
Replied by jonplace on topic Re:slight grease leaking from ball joint
ok guys thanks, really appriciate the sound advice. its gonna be this weekend before i get a chance to have a look due to work stuff
also the brakes are now playing up my daily driver (VW golf) which also needs sorting, just bought one of them wind back tools.
going to be a busy weekend :laugh:
09 Jul 2009 11:10 #983
by kirkynut
Replied by kirkynut on topic Re:slight grease leaking from ball joint
I hope the weather is good for you then!
- jonplace
28 Jul 2009 06:07 #1071
by jonplace
some good and bad news. good news is i replaced the offside kingpin bearings at the weekend and that sorted that out
bad news is that the nearside is now starting to show signs of failure
not a difficult job just very messy, oil and grease everywhere.
the bottom bearing fell to bits as it came out, the outer holder was also cracked as you can see in the picture, all sorted now
29 Jul 2009 09:57 #1073
by kirkynut
You're lucky in some respects that the bearing race/holder was falling apart as they can be a pain to drive out sometimes! Putting the new one in level to match the new bearing is not so difficult, so it sounds like it did you a favour!
It's not a difficult job is it, just not one you look forward to for the reasons you've said.
Time to create page: 0.170 seconds
