shocks
  • tiny
06 Jul 2009 09:50 #942 by tiny
shocks was created by tiny
Hello everybody ive just got one half of my 3 inch lift kit.Having probs finding four shockers dont no which ones to fit.Im been told that the thick body shocks rub on the springs.Anybody have any clues as to what i can fit make and where to get them from.Thanks tiny
  • Jamie
06 Jul 2009 16:38 #948 by Jamie
Replied by Jamie on topic Re:shocks
I run ES1000 shocks on mine and there is no problem with rubbing
the ES3000 as far as i know don't rub on the springs either
the ES9000 are thicker but with them been gas charged instead of oil
you can run with them inverted with no problems at all
Jamie
  • tiny
06 Jul 2009 17:37 #951 by tiny
Replied by tiny on topic Re:shocks
Thanks jamie i think i will put the es1ooo on.What size tyres do you run on yours?
Thanks tiny
  • Jamie
06 Jul 2009 17:53 #952 by Jamie
Thanks tiny
Hi Tiny,
I run size 235-75-15 at the moment but soon i'll be
going up to 31 10.50 15's more ground clearance :silly:
Jamie
  • tiny
06 Jul 2009 18:09 #953 by tiny
DO the tyres rub or have you had to trim the arches out
thanks tim
  • Jamie
07 Jul 2009 14:05 #955 by Jamie
thanks tim
Hi Tiny,
Errmmmm only a little bit on the rear of the front arch
around an inch by about three inch has been removed it sound's
worse than it is.
However, i have a 3" suspension lift and a 2" body lift.
Ideally i could do with trimming them all the way around
as they do rub ever so slightly on the rear when at max articulaton
which is not too often so i havn't bothered.
Jamie
Time to create page: 0.171 seconds
