Knuckle Bolts
vitara_mad wrote: mine will be alot easyer to get to the bolts next time as i can take the hub off out of the way nice & easy now cus ive fitted vitara hubs & don't need a special tool to get them off & can fit manual fwh's without the need for any spacers
Didn't know they were interchangable - does it keep the wheel in the same place or push it out further to give you more girth ( I mean width but really wanted to use the word girth for some reason).
- vitara_mad
- Visitor
i did not know either until i took one of the jimny cus i sheared the fwh bolts & thought it would be easyer to use the bench drill to try drill the bolts out & i had some vitara hubs in the garage so i compared them & the only differance i could see was on the back where the seal is for the vacume hubs but don't need that seal now so its all good.
they are the same size so the wheel stays in the same place as it did & you dont need a special tool to change the bearing either so thats another bonus
- adamjimny
- Visitor
- vitara_mad
- Visitor
adamjimny wrote: what year vitara hubs did you use......would make it cheaper/easier then
they are all the same on vitara's but mine was of a 94
