Do I need adjustable panhard rods?
- Bigchridy
09 Jan 2011 21:41 #9270
by Bigchridy
Do I need adjustable panhard rods? was created by Bigchridy
I'm going to fit my 3" lift at the weekend and was wondering if I would be alright driving the Jimny with the standard panhard rods?
I will be buying some adjustable ones just not till I have sold me disco! So I might have to do 1-2 pay and play days with the standard ones on. Just want to make sure I'm not going to damage anything!
Cheers
Chris
Cheers
Chris
09 Jan 2011 22:39 - 09 Jan 2011 22:48 #9280
by facade
Replied by facade on topic Re: Do I need adjustable panhard rods?
The rods will be too short and pull the axles over to one side, and make it lean.
With the lift kit fitted:
Whip the bolts out of one end and free both the rods.
Roll the car back and forwards a bit, and bounce it to settle the springs.
The bolts wont go back in now by miles :ohmy:
Don't ask me how to get them back in again though :blush:
I'd saw straight across the tube, measure the gap with both ends fitted, and splice a piece in
Last edit: 09 Jan 2011 22:48 by facade. Reason: changed to future tense
- Adamski
09 Jan 2011 22:49 #9283
by Adamski
Leaving the standard rods on for a short amount of time should be OK. They will put a bit of excess strain on the trailing arm bushes but they shouldn't cause any damage. If you left them on for a long time it could become an issue.
Replied by Adamski on topic Re: Do I need adjustable panhard rods?
Bigchridy wrote: I'm going to fit my 3" lift at the weekend and was wondering if I would be alright driving the Jimny with the standard panhard rods?
Cheers
Chris
- biggaz
10 Jan 2011 13:26 #9301
by biggaz
Replied by biggaz on topic Re: Do I need adjustable panhard rods?
hmm, i need !
10 Jan 2011 13:46 #9305
Replied by mlines on topic Re: Do I need adjustable panhard rods?
I can get adjustable panhard rods made up.
These are currently £70 per set EXCHANGE
You may have read that I am having problems with the bushes, which means that bushes are currently not available.
If you have a set of rods complete with bushes and can do without them for about 3 weeks then I can sort you out. Equally, if you are prepared to take pot luck with what bushes you get then you can have one of the sets I have exchanged, but these come with whatever bushes were in them originally or even NO BUSHES if they were removed by the original owner.
- Bigchridy
10 Jan 2011 19:43 #9336
by Bigchridy
Replied by Bigchridy on topic Re: Do I need adjustable panhard rods?
Thanks for the posts.
Martin I may have to take you up on the exchange panhard rods but not for a while as I'm skint at the min!
Time to create page: 0.182 seconds
