Gearbox leak i think?
- g4vcn
09 Jan 2011 10:42 #9155
by g4vcn
Gearbox leak i think? was created by g4vcn
Im not 100% sure but i think i have a leak from my gear box on the end with the prop. There is signs of oil around that area. Oil has flicked up to the underside of the car so guess its from where the prop is spinning. Is there a seal that can be replaced without having to remove the gear box? It dont look like its going to be an easy job.
Thanks
Gav
Thanks
Gav
09 Jan 2011 13:10 #9165
by facade
Replied by facade on topic Re: Gearbox leak i think?
In principle it is dead easy.
Pull the propshaft out, extract the oilseal, smear the lip of the new one with grease, drive it in, refit prop.
In reality I expect that the transfer box will have to come out to get at it properly, not a major job.
Before you change it, there is a breather to the gearbox. If this is blocked with mud it will pressurise and blow oil out. I'm afraid I have no idea where it is though.
A quick test is to undo the filler bung shortly after a run. If it goes PSSSsssshhhh! then you have a problem with the breather.
The following user(s) said Thank You: g4vcn
- biggaz
09 Jan 2011 13:20 #9168
by biggaz
Replied by biggaz on topic Re: Gearbox leak i think?
Is it similar to what ive just done on my transfer box? As in same sort of job?
If so, it was quite straight forward on the transfer box.
Is yours splashing oil on the floor near the gearbox or the transfer box?
- g4vcn
09 Jan 2011 13:50 #9169
by g4vcn
Replied by g4vcn on topic Re: Gearbox leak i think?
its near the gear box. it has splashed oil all arround that area. i havnt noticed it dripping onto floor as of yet. but it has made quite a mess on the rubber boot that covers the gear leaver on the underside.
Is it just one of thoes things or could it be due to having a 2 inch body lift and 3 inch suspension putting strain on the props?
gav
gav
- biggaz
09 Jan 2011 14:29 #9171
by biggaz
I asked that question just a few days ago when my transfer box started leaking, nobody answered lol!
Ive noticed the prop spacers up for sale, so did wonder myself as this seems like the same thing as mine but at the gearbox end. Mine splashed gunk all over the handbrake cables and floor etc.
Fitted the new seal yesterday with new transfer oil, never looked to see if its still leaking cos im scared haha.
Dont want to make it a habit of having to do them though either.
- g4vcn
09 Jan 2011 16:09 #9174
by g4vcn
i need to have a closer look at it to make sure its comeing from there. its hard to see the gearbox side of the prop because of a bracket/guard under it. i hope it is an easy fix as luck isnt going my way with this car so far. Still havnt found a front diff for it from the last problem.
gav
gav
Time to create page: 0.443 seconds
