fault codes
- bryandenham
15 years 10 months ago #8519
by bryandenham
fault codes was created by bryandenham
hiya from the isle of man,
2002 jimny..3" KAP springs.....e1000s......jimnybitz shock extenders....NO anti roll bar...... 195 Kumhos.
chassis...JSAFJB33V00123426
I have tried two code readers but neither will communicate with vehicle. Any ideas?? It has the appropriate plug so I presume it is OBD11 compliant.
code reader 1.....pro scan with ELM 327 interface
code reader 2.....Autel Maxscan 405
Both readers work correctly on my other vehicles.
Thanks, Bryan D
Thanks, Bryan D
- Keefe
15 years 10 months ago #8520
by Keefe
Replied by Keefe on topic Re: fault codes
Don't quote me on this but I heard a rumour that although it looks like it's OBDII, it's wired different.
Something like that.
I'm sure you'll find mention of it in the SEARCH facility, top of the page.
Or someone will be along to tell you.
Keith
Keith
15 years 10 months ago #8547
by facade
Replied by facade on topic Re: fault codes
My 2001 Japanese built twin cam works with an elm327, Yours should, unless it has the single cam engine with a cam belt.
- srcars
15 years 10 months ago #8772
by srcars
? My 53 plate single cam engine with belt works with elm327 ?
Replied by srcars on topic Re: fault codes
facade wrote: My 2001 Japanese built twin cam works with an elm327, Yours should, unless it has the single cam engine with a cam belt.
- bryandenham
15 years 10 months ago #8797
by bryandenham
Replied by bryandenham on topic Re: fault codes
Thanks guys, yes, its a single cam and yes all the forums agree it has the socket but it's not wired to be compatible with the readers so it seems that I will just have to resort to the old methods as usual.
Just out of interest, I corrected the caster angle for the 3" lift by drilling two extra holes below the origonals, welding a couple of mini skid plates onto the brackets which both strengthens and protects the bracket and bolt up using the origonal bolts. Simples !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
AND very cheap!!!!!!!
Keep on slippin an slidin.
Bry D
Bry D
15 years 10 months ago #8930
by kirkynut
Replied by kirkynut on topic Re: fault codes
I can't think that a 2002 Jimny would be single cam. They went to twin cam about 2000.
The registration date does not always mirror the manufactured date though.
Are you sure it's single cam?
If it's a twin cam it will be OBD2 but single cams are OBD1
The usual suspects in the way of failed components are cam sensor and lambda sensor(s)/ cat.
What symptoms do you have with your fault codes or do you not have any?
An emmissions test will tell you if it's the cat.
