locking hubs to on
- clyde
27 Dec 2010 22:40 #8210
by clyde
locking hubs to on was created by clyde
hi again everyone what is the best way to lock the original hubs to on, if the vacuum is not putting them on cheers karl
- ooky_123
27 Dec 2010 23:18 #8213
by ooky_123
Replied by ooky_123 on topic Re: locking hubs to on
take each one off (6 torx bolts), and unlock the inside coller (Martin has an article about it).
Then replace.
Takes about 20 minutes to do.
Then replace.
- clyde
28 Dec 2010 07:11 #8217
by clyde
Replied by clyde on topic Re: locking hubs to on
cheers mate, take it they just stay on then you dont have to put a bolt in to it then. they'll only dissengage if you open it up again
- ooky_123
28 Dec 2010 11:45 #8223
by ooky_123
I believe so mine havnt dis-engaged since I manually locked them 3 months ago.. if your unsure, just disconnect the vac pipe from the actuators under the battery.
I have manual hubs and a spacer ready to be fitted, but I havnt had time to overhaul them.
- dc5
28 Dec 2010 19:20 #8257
by dc5
Replied by dc5 on topic Re: locking hubs to on
You will need an E10 torx socket to remove the bolts;)
- clyde
29 Dec 2010 07:29 #8264
by clyde
cheers evryone all sorted, wasted some time tying to find the actual fault , thought i'd sorted it and then it packed up again, so then just decided to lock them on and disengage the vacuum. looks like it might be the vsv2 solenoid /wiring thats being the pain. had all vac pipes off and blew through with air line no leaks, and everything clear. never mind eh.
Time to create page: 0.283 seconds
