4x4 problem
- clyde
27 Dec 2010 08:18 #8153
by clyde
4x4 problem was created by clyde
hi everyone, wondering if anyone can help,my little suzi seems to have stopped selecting 4 x4. the problem seems to have started from when i hosed the underside off. i noticed 1 of the vacuum pipes had come off from the hub, so i reattatched.not had to use the 4x4 till yesterday ,you select 4x4 and the light on the dash comes on( stays on and does not flash)so reading up a bit this seems to be working fine. but you can not hear the front hubs (clacking in or out),any suggestions as to where to start looking would be appreciated. i have also checked the fuse and that is ok. it is a 2000 model 1.3 16 v. many thanks karl:ohmy:
- bertbuckie
27 Dec 2010 08:21 #8156
by bertbuckie
Replied by bertbuckie on topic Re: 4x4 problem
Are you sure its not engaging quietly? have you tried driving to see if you can tell the difference ?
- clyde
27 Dec 2010 08:31 #8159
by clyde
Replied by clyde on topic Re: 4x4 problem
yes mate did last night , it just spins up on the back wheel, but then for a moment when i was switching between 4x4 +2 wheel you started hearing the hubs clicking in , and then nothing again.
- bertbuckie
27 Dec 2010 08:49 #8160
by bertbuckie
Sorry then no idea
Im a newbie here tho, theres many others with far far more knowledge - hope you get it sorted, Bert
- clyde
27 Dec 2010 09:20 #8161
by clyde
no probs mate, just typical of my motors waits till it snows then i have to fix
- Foxtrot
27 Dec 2010 18:28 #8195
by Foxtrot
Replied by Foxtrot on topic Re: 4x4 problem
Hi,
I'm not to sure on how to fix it if it is broke, but you will know for sure if it is working if you engage 4x4 and put it on full lock whist on firm ground, the front and back tyres will start fighting with each other especially in reverse. If it is working don't do it for too long as it will damage something.
All the best
All the best
Time to create page: 0.203 seconds
