Jimny Rear Panhard Relocation Bracket
  • shootinginger@yahoo.co.uk
26 Dec 2010 15:48 #8132 by shootinginger@yahoo.co.uk
Jimny Rear Panhard Relocation Bracket was created by shootinginger@yahoo.co.uk
i take it this will sort out the axles moving over to the right, has anyone brought one or do i not need one?
www.jimnybits.co.uk/shop/index.php?_a=viewProd&productId=97
  • adamjimny
26 Dec 2010 16:51 #8133 by adamjimny
Replied by adamjimny on topic Re: Jimny Rear Panhard Relocation Bracket
it does re center it but only so much depends on how much lift you have.
26 Dec 2010 17:13 #8135 by shootinginger@yahoo.co.uk
Replied by shootinginger@yahoo.co.uk on topic Re: Jimny Rear Panhard Relocation Bracket
would be abloy 3inches woukld it help?
26 Dec 2010 20:53 #8149 by facade
You simply need a bracket that moves the panhard rod up as far as you moved the axle down, so if you dropped the axle 3" there needs to be 3" centres on the bracket holes.
It would be easier to just lengthen the panhard rod though.
If it were me I would just saw through the rod, bounce the suspension and then measure between the saw cuts to give the required filler length, turn a spigot and weld it in.
(yes you can weld a panhard rod for MOT, if you make a good job of it)
Time to create page: 0.162 seconds
