A little agrivating fault !
  • DAVE T
27 Dec 2010 19:30 #8200 by DAVE T
Replied by DAVE T on topic Re: A little agrivating fault !
hi does it feel like its running out of petrol and the rev counter bounces when you put your foot to the floor , if thats happening it sounds like its a cranckshaft sensor, mine did the same thing and fitted a new sencor problem sorted.hope this helps.
  • Fieldsports
27 Dec 2010 20:00 #8205 by Fieldsports
Replied by Fieldsports on topic Re: A little agrivating fault !
DAVE T wrote: hi does it feel like its running out of petrol and the rev counter bounces when you put your foot to the floor , if thats happening it sounds like its a cranckshaft sensor, mine did the same thing and fitted a new sencor problem sorted.hope this helps.
Hello.
No the rev counter has no effect with this problem.
Its hard to describe when typing but its like it begins to run on 3 cylinders but I do not believe it is for some reason.
If I move the my foot even a little ( and I mean a little, like the pressure of my foot within my shoe ) one way or the other it cures the fault.
It is only at a certain speed...if at the same speed and the motor is climbing a slight hill it will not do it.
I would say I have to be on flat road no uphill or downhill to make it do it.
Thanks
  • clyde
27 Dec 2010 22:43 #8211 by clyde
Replied by clyde on topic Re: A little agrivating fault !
does it do it on a certain level on the fuel gauge at all, its just that im begining to wonder if mine is more through fuel, will keep an eye on mine to see when it does it again and will let you know
  • Fieldsports
27 Dec 2010 22:46 #8212 by Fieldsports
clyde wrote: does it do it on a certain level on the fuel gauge at all, its just that im begining to wonder if mine is more through fuel, will keep an eye on mine to see when it does it again and will let you know
Naah not really it does not matter how much fuel is in...I filled up today and the last time it did it I was about 1/4 tank.
Steve
  • Foxtrot
30 Sep 2011 16:56 - 30 Sep 2011 16:57 #22838 by Foxtrot
Replied by Foxtrot on topic Re: A little agrivating fault !
Hi Steve, did you manage to sort your problem out? my 2006 seems to do the same, it is more noticeable at idle, every now and again the engine feels lumpy like it is on 3 cylinders
Last edit: 30 Sep 2011 16:57 by Foxtrot. Reason: wrong name
  • dirtydogz
30 Sep 2011 17:00 #22839 by dirtydogz
Replied by dirtydogz on topic Re: A little agrivating fault !
yes he did he sold it.
