A little agrivating fault !
- Fieldsports
25 Dec 2010 22:31 #8107
by Fieldsports
A little agrivating fault ! was created by Fieldsports
Here I go trying to explain this one.
I have a old S reg jimny with the 16v 1300cc in it.
OK...when I drive ONLY SOMETIMES at about 55 - 58 mph with little throttle and move the throttle pedal off very slightly it goes as if it is running on 3 cylinders...or as if you have turned the key off momentarily.
If I press the throttle even a little it is cured until I let off a little.
This is not all the time ( Maybe once a week / fortnight )
Lower speeds spot on higher speeds spot on.
Done it for ages ! Does not bother me 2 much but I would like to know what it is.
If it was throttle position it would happen on acceleration or at the same position at lower speed or gears.
What do you think ?
I have not looked at it yet but I thought it was maybe a coil pack or cam sensor but at this point it does not make sense to change these due to the fact it only seems to happen when I am in a motorway run at a constant speed.
Thanks People for any advice you can throw at me !
Steve
What do you think ?
Steve
26 Dec 2010 07:01 #8110
Replied by mlines on topic Re: A little agrivating fault !
It might be a coil pack, although the ECU seems pretty good at putting up the warning light if anything is wrong with a coil pack.
- clyde
26 Dec 2010 18:22 #8142
by clyde
Replied by clyde on topic Re: A little agrivating fault !
hi mate mine does the same , but i thought it felt more like fuel starvation, or some water going through with the petrol, ie crappy petrol:angry:
- Fieldsports
26 Dec 2010 18:32 #8144
by Fieldsports
Replied by Fieldsports on topic Re: A little agrivating fault !
Yea that's the initial impression as if the fuel is cutting off.
But its only at a certain speed and throttle position.
I can try the coil pack martin as I have a couple of sets here.
I am intrigued as I am not the only one with this problem.
Clyde says his does the same.
Steve
Steve
- bertbuckie
27 Dec 2010 08:25 #8157
by bertbuckie
I agree, my signum did this and it was the coil pack....
Replied by bertbuckie on topic Re: A little agrivating fault !
mlines wrote: It might be a coil pack, although the ECU seems pretty good at putting up the warning light if anything is wrong with a coil pack.
- Fieldsports
27 Dec 2010 12:13 #8165
by Fieldsports
Hi,
I changed both coil packs this morning and took it for a long motorway run to see if I could get the fault to happen again.
Drove about 15 mile no prob, then on the return journey I felt the normal hick that it does.
Well that eliminates the coil packs !
I fitted a cam sensor while I was under the bonnet as well.
Any more ideas lads ?
Its definitely when the throttle is in a certain position at a certain speed as like I say if I ease off a midges knacker or press it a midges knacker it stops at once.
It happened before as usual 55 mph !
Went up to 60 mph and perfect.....dropped down to 50 and once again perfect.
It is intermittent as this can not show itself as a fault for 2 to 4 weeks ( you sort of forget about it ) and then the little hick comes back. ( No engine light comes on and never has ).
Thanks Steve :blink:
Time to create page: 0.222 seconds
