Half shaft spline counts and CV's
14 Dec 2010 19:23 #7563
by kirkynut
Half shaft spline counts and CV's was created by kirkynut
I understand that there are 2 different CV's for Jimny's and they differ due to spline count on the end of the shaft that goes into the CV.
What are the 2 numbers of splines?
Also, do the number of slines at the end of the front shafts that goes into the diff differ or are they all the same so that all diffs can accept all shafts?
Also, are all rear diffs and shafts the same in respect of spline counts?
Cheers
Cheers
14 Dec 2010 19:51 #7572
Replied by mlines on topic Re: Half shaft spline counts and CV's
Why don't we start an information gathering exercise.
Jamie has already fallen foul of a spline problem on the transfer box to gearbox mini-prop.
If everyone taking their car apart at any time counts the splines on the part they are working on and posts this to me stating the model and year it comes from then we can create a definitive table as a reference.
15 Dec 2010 21:56 #7634
by kirkynut
Replied by kirkynut on topic Re: Half shaft spline counts and CV's
OK then - I'll have a look at the front shafts I have taken out of my old original front axle but I'm not taking off the CV's as they don;t need to come off and I'm not going through that in the name of research yet!
When I next take the front apart I'll see if those front shafts go into the diff on my second hand front axle but I don;t know the year of that.
I have the rear shafts out of my spare rear axle too but don;t know the year of that - so I'm not much use yet!
10 Jan 2011 23:10 #9358
by kirkynut
Whilst stripping,cleaning and regreasing my front hubs today I looked at my two sets of front shafts and cvs.
The ones in the car now are from my second hand axle of unknown age from a convertible scrapper. The spares are my originals from my 2000 Jap built model.
The cvs look different and my original shafts have a couple of ribs inboard of the thicker part that the axle tube seal runs on whereas the others don't.
Both fit the same diff so they have the same number of splined no matter what age and therefore the same diffs, autos might differ.
I didn't take the cvs off to see if they interchanged as that's agro I didn't need. I expect they differ in some way.
11 Jan 2011 08:52 #9369
by Obarno
Replied by Obarno on topic Re: Half shaft spline counts and CV's
I suspect the diff splines across the different models and years are all the same as ARB state that their lockers fit all ratios. They are obviously different back and front - 22 spline front and 26 rear.
11 Jan 2011 18:50 #9398
by kirkynut
Yep I'd been thinking the same but with Kam Diffs lockers.
So it seems the only difference there is on any of the shafts is how some CV's fit some shafts and I think - but I'm not sure - that there only 2 types of CV.
Has anyone ordered the wrong one before to see how they differ?
