spare tyre
- dirtydogz
10 Dec 2010 13:32 - 10 Dec 2010 19:08 #7291
by dirtydogz
spare tyre was created by dirtydogz
Is it OK to use a 205/70/15 as a spare with 205/75/15 on my jimny.
Last edit: 10 Dec 2010 19:08 by dirtydogz.
- ooky_123
10 Dec 2010 13:39 #7292
by ooky_123
Replied by ooky_123 on topic Re: spare tyre
yes.!
Be honest though, I would only my spare to "Get me home" .. snf certainly wouldnt run different sized tyres any longer than I had to.
we run 215x80x15's and still have the origional 205x70x15 on the back
- dirtydogz
10 Dec 2010 14:56 - 10 Dec 2010 15:31 #7296
by dirtydogz
Replied by dirtydogz on topic Re: spare tyre
Thank you Jason that will save me £85.
BAZ.
BAZ.
Last edit: 10 Dec 2010 15:31 by dirtydogz.
- biggaz
10 Dec 2010 16:54 - 10 Dec 2010 16:54 #7304
by biggaz
Replied by biggaz on topic Re: spare tyre
on the subject of the spare tyre, how does the spinny nut come off?
Also you think a 215/75 mud will fit on the door on a 15x7 modular?
Last edit: 10 Dec 2010 16:54 by biggaz.
- dirtydogz
10 Dec 2010 18:53 - 11 Dec 2010 09:44 #7311
by dirtydogz
I don't know about the spinny nuts.if it's the spare tyre cover it has one nut to hold it on set in a hole in the cover.
About fitting 215/75 on back door,why don't you try one of your wheel+tyres on the back door, if you need more room at the back of the tyre you could take the rubber door stop off or cut them down,mind your window wiper.
hope this helps,BAZ.
Last edit: 11 Dec 2010 09:44 by dirtydogz.
11 Dec 2010 11:03 #7326
by kirkynut
Replied by kirkynut on topic Re: spare tyre
Bits4vits used to do a spacers for the spare wheel to move it out but I can't see them on his site now. I have one, its awesome. Otherwise a cheap wheel spacer.
The spinny nut might be a locking wheel nut to stop it getting picked. No good if you don't have the key.
I had to take the spinning ring off mine with a screwdriver and undo the nut with a pair if mole grips. You can buy tools to remove all locking wheel nuts in halfords. Great for a thief!
Time to create page: 1.509 seconds
