M13A Coolant vanishing
23 Nov 2026 19:28 - 23 Nov 2026 19:54 #265611
by Alastair
M13A Coolant vanishing was created by Alastair
Hi,
I recently acquired my second Jimny and the guy I bought it from conveniently forgot to tell me it’s using / losing coolant.
After each drive, the level in the rad drops by about ½ a cup and the expansion bottle goes from ‘Full’ mark to empty.
Having done a top end rebuild of the previous 05 model, I knew to check the coolant before driving so no overheating surprises yet.
This one is a 2012 1.3L M13A VVT.
Should I assume the head gasket is gone and get on with replacing it or are there other things it could be?
Aside from the head gasket kit (that included valve stem seals) and head bolts, what other bits and pieces will I need to avoid a ‘Gotcha’ moment.
I would hate to start the job and then have to stop and wait for something that didn’t get bought in advance.
My shopping list so far:
Head gasket kit (inc. valve stem seals)
Head bolts
Crankshaft oil seal
Timing chain cover (sealant, no gasket)
Oil pump O’ring
Metal water pump O’rings (2of, different)
Radiator cap
Water pump (sealant, no gasket)
Thermostat (+ gasket)
Block core plugs
HT sealant
Thanks in advance for any wisdom and advice.
Head bolts
Crankshaft oil seal
Oil pump O’ring
Radiator cap
Block core plugs
HT sealant
Last edit: 23 Nov 2026 19:54 by Alastair. Reason: Tidying up paragraphs and grammar
- Thank you received: 2004
24 Nov 2026 04:23 #265615
Replied by Lambert on topic M13A Coolant vanishing
I had mine done for me but I think you have thought of everything.
Time to create page: 0.069 seconds
