Axle Breather
23 Nov 2026 18:31 #265609 by mike ryan
Axle Breather was created by mike ryan
Hi - Can you tell me if this welded lug is the standard on the Jimny rear axle?
ps Black bits are silicone.
24 Nov 2026 03:43 #265613 by fordem
Replied by fordem on topic Axle Breather
That does not look like the stock breather, but it is too badly mangled for me to be certain - I don't recall it having a large circular base like the one shown in the picture.
The stock axle breather is a short stub of pipe maybe 10~11 mm diameter, and perhaps 25 mm long with a jiggle cap over it - mounted slightly left of top center on the housing.
24 Nov 2026 06:22 #265617 by Lambert
Replied by Lambert on topic Axle Breather
That looks like the remnants of a threaded bung which I don't recognise as being standard. Maybe see if it will unwind and allow you to use a new fitting?
Time to create page: 0.080 seconds
