Squealing on Gen 3 2009
19 Nov 2026 17:34 #265598
by jimjaidee
Squealing on Gen 3 2009 was created by jimjaidee
Ive had jimny 2009 since July (100k)and it had a coolant leak in August that got sorted but since then its squeals so loud mainly after rain?!..Mechanics seemed to think it was coolant that had spilt on the belts and it would wear off..today came back from 3km drive (after rain)very loud squealing (though not at start up?) dad wonders are belts too loose or is it alternator or cam shaft pully..…any suggestions please…its been in 2 different garages 5 times since August on various things but never squeals for the mechanics!!..they dont seem to know what it is.. Im at wits end and ive already spent lots of money on her ..im used to old cars but im wondering if anyone can advise me ...id be very greatful thank you
19 Nov 2026 18:22 #265599
by facade
Replied by facade on topic Squealing on Gen 3 2009
It could be contamination on the belt, but-
Check the pulley on the crankshaft. The outer ring with the belt grooves on comes apart from the inner hub that is fixed to the crankshaft, there is a thin layer of rubber between the two that de-laminates.
Because of the design of the pulley, the tension of the fan belt twists it apart, the more you try to tighten the belt the worse it gets.
Eventually, the whole outer ring will fall off and you will lose the belt, the ignition light will come on because the alternator stops and the temperature will rise very quickly because the water pump isn't turning, so you have to switch off and wait for recovery.
Anyway, if you try and lever the outer ring of the pulley off it should not move. If it does you need a new pulley PDQ, they are about £100 and are easy to fit if the centre bolt will come undone, otherwise the rim around the centre bolt has to be cut off and a new bolt fitted to the new one.
19 Nov 2026 18:45 #265600
by Peabody
Replied by Peabody on topic Squealing on Gen 3 2009
I had same problem, was told it was the tension pulley bearing. Changed that but still squealing, turned out belt was lose and the pulley needed adjusting. Recommend large Allen key with short extension and slim ratchet spanner or socket with strong slim hands if you don't want to take out radiator
- Thank you received: 679
21 Nov 2026 14:00 #265602
Replied by DrRobin on topic Squealing on Gen 3 2009
As Facade says I would check the crank pulley for play/worn out rubber drive, they fail fairly quickly when been in a few years.
My 2012 had a bit of belt squeal now and again, but like you I thought it was belt tension, until both belts came off. Fortunately it happened outside the house and I found out the pulley was shot.
If it goes you loose alternator and water pump, so your engine can easily overheat.
Time to create page: 0.088 seconds
