which shocks?
08 Dec 2010 09:37 #7200 by Obarno
Replied by Obarno on topic Re: which shocks?
My brother has Rough Country on his Jimny and the ride is very harsh compared to mine which runs on OME. It would seem that the shocks which are designed for a specific vehicle have to be better than a general shock that is only selected because of its size. For that reason I would be interested to know what the ride is like on Martin's Trailmaster. I can't help thinking it would be good as they are designed specifically for the car.
  • oxford_bloke
08 Dec 2010 12:54 #7212 by oxford_bloke
Replied by oxford_bloke on topic Re: which shocks?
I have a set of these front and rear
www.roughcountry.com/shocks_rc8000.html
although I haven't driven the car yet it is still in the build stage the suspension is all done, having done a 4.5inch lift I have a feeling I it is going to be a "spongy" ride but then this is what I'm after as I won't be doing long distance driving in it. so if i was using it as a daily driver then I would go for a harder shock minus the anti roll bar as this limits travel a fair amount on the axles off road.
  • shootinginger@yahoo.co.uk
08 Dec 2010 19:19 #7244 by shootinginger@yahoo.co.uk
Replied by shootinginger@yahoo.co.uk on topic Re: which shocks?
ok i will bear all this in mind, i think i might go for the es1000, due to wnat to keep it on the cheap as much as possiable, its going to work out just under 500 for the shocks+springs, brake hoses and castor correcters, and on the other side i drive to sheffield every other weekend to see the gf at uni.
  • Gromit
08 Dec 2010 19:52 - 08 Dec 2010 19:54 #7245 by Gromit
Replied by Gromit on topic Re: which shocks?
Adamski wrote: All I can say is I have es3000s and they make for a very harsh ride. I would love to know what people make of their ride with es1000s.
ES3000's are a bit too stiff for a Jimny, I run ES1000's and they are fine for all uses.
Last edit: 08 Dec 2010 19:54 by Gromit.
08 Dec 2010 20:41 #7246 by shootinginger@yahoo.co.uk
ok then mate thats what ill go for then the es1000, i just need to get the shocks, springs,extended brake houses and castor corectors to make the 3inch lift work?
  • biggaz
08 Dec 2010 21:10 #7249 by biggaz
Replied by biggaz on topic Re: which shocks?
Yeh, fit hoses and lift kit, try it and see how it feels. Then you can fit the caster kit later if u like... havnt fitted mine yet. Not too bad though but some are worse than others it seems.
