Tips for saggy seat belt
27 Sep 2026 15:13 #265319 by saxj
Replied by saxj on topic Tips for saggy seat belt
Clean the slot that the belt runs through at the top of the B pillar. That seems to have more impact than cleaning the rest of the seatbelt assembly.
27 Sep 2026 17:58 #265324 by facade
Replied by facade on topic Tips for saggy seat belt
facade got it just right.
My 42 year old gen 2 jimny from 1984 spins the belt back just fine so it is not that it is difficult to make one that works...
In all seriousness I think the spring is very weak to make it comfortable to wear and stop it pressing on you.
As you move around the belt slack slowly retracts itself and keeps a degree of tension, then if the tensioner fires in an accident it tightens enough.
The belt can't retract quickly if there is a bit of a twist in it, which is why it is forever getting caught in the door when it shuts.
If I straighten the belt and wait it will slowly pull itself in, which is presumably how it passes MOT: in the notes for 7.1.2 it says
Some types of retracting belt might need manual help before they retract. If a temporary device is fitted to prevent retraction, you can remove it.
Certainly mine is not noticeably dirty/greasy and I believe that this is how it is supposed to be.
28 Sep 2026 17:57 #265333 by yakuza
Replied by yakuza on topic Tips for saggy seat belt
Done this and even polished it. helps a few days or a week and then it start to sag again.
also put teflon tape on it, same result.
Would be interesting to know it this is a problem on all gen 3 or just some?
mine are 2005 with pyro.
30 Sep 2026 12:35 #265339 by saxj
I've had it happen on my 2008 and 2012 Gen 3's and now my 2018 Gen 4. I haven't tried fixing the Gen 4's yet. I'll see if cleaning helps. It didn't happen on my SJ410, it didn't have inertia real belts :D
Time to create page: 4.566 seconds
