Oil leaking from rear
08 Sep 2026 10:47 #265227 by yakuza
Replied by yakuza on topic Oil leaking from rear
Check that the breather on top of the axle is free and the level is correct. It could be a blocked breather is pushing oil past the shaft seal?
Good point here!
This has happened to me a few times, and even made my ARB stop working properly. Spray the breather cap with your favourite lube/rust loosening something and wiggle it with pliers. (and later attach a hose to the thing under the cap and run it up high)
Time to create page: 0.316 seconds
