Oil leaking from rear
- davidandped
- Junior Member
- Thank you received: 3
07 Sep 2026 17:17 - 07 Sep 2026 17:22 #265216
by davidandped
Oil leaking from rear was created by davidandped
My JB74 has been making a popping sound from the rear for a few weeks now. Thought I’d check underneath today and oil was peeing out of the rear, I’ve taken a video and tried to attach it to this post if anyone can advise me how to fix it! Thanks
youtube.com/shorts/GpsFabEQa1k?is=nseWSBv-NdcQCLKN
Last edit: 07 Sep 2026 17:22 by davidandped.
07 Sep 2026 17:34 #265217
by fordem
Replied by fordem on topic Oil leaking from rear
That liquid looks a little too thin to be gear oil, I'd suggest you check the brake fluid reservoir ASAP.
The following user(s) said Thank You: davidandped
07 Sep 2026 18:34 #265218
Replied by mlines on topic Oil leaking from rear
I agree it looks thin for diff oil but with that much leaking there would be no brakes already
I would go for a diff that is full of water and oil, have you been wading it?
- davidandped
- Junior Member
07 Sep 2026 18:44 #265219
by davidandped
Replied by davidandped on topic Oil leaking from rear
No, haven’t been off-road in it since the Big Jimmy meet, I did change the diff oil a few weeks ago and it was as clean as a whistle
08 Sep 2026 07:50 #265223
Replied by yakuza on topic Oil leaking from rear
Smell and feel the oil on your fingers, brake fluid is less lubricative if that is a word.
You may have leftovers from your gear oil change and can smell/feel if it is the same?
And/or smell/feel the brake fluid in the reservoir?
(I did not suggest "taste" here thank god..
- Thank you received: 2001
08 Sep 2026 09:42 #265225
Replied by Lambert on topic Oil leaking from rear
Check that the breather on top of the axle is free and the level is correct. It could be a blocked breather is pushing oil past the shaft seal?
Time to create page: 0.169 seconds
