Diff lockers
- mathias4200
03 Sep 2026 07:15 #265185
by mathias4200
Diff lockers was created by mathias4200
Hey! I’ve ordered e-lockers, meaning electric differential lockers, for both the front and rear axles. Has anyone here installed differential lockers and know if there’s anything else I should order before I start tearing things apart?I’m thinking about gaskets, bearings, or any other parts that might need replacing or that can easily get damaged during disassembly. I’d rather have everything ready beforehand so I don’t end up stuck halfway through the job waiting for parts.
03 Sep 2026 07:28 - 03 Sep 2026 09:43 #265187
by Busta
Replied by Busta on topic Diff lockers
Depends how thorough you want to be. In theory you just need the usual sealant and oils (no gaskets), but you will be doing most of the work required to change the rear wheel bearings and axle seals so it might be worth doing them while it's apart.
The front depends which route you take to pull the shafts out. If you're taking the kingpins out then it would be worth putting new bearings and driveshaft seals in. If you're just removing the stub axles then that's not necessary. You have to move the vacuum hoses so if they are crusty be prepared to replace them with some suitable 4mm id tubing.
ETA: I forgot about the diff carrier bearings. It's worth replacing these as otherwise you would need to remove the old ones and fit them to your new carrier. You don't need to touch the pinion shaft, but you could take the opportunity to replace the pinion bearings and seal. You will also need a new crush tube if you do this.
The few times I've changed diffs I've just done the minimum work needed and I haven't had any further issues.
Last edit: 03 Sep 2026 09:43 by Busta. Reason: Add information
03 Sep 2026 14:59 #265189
by fordem
Replied by fordem on topic Diff lockers
I'd say Busta's done a pretty good job of covering the bases, what he didn't touch on is what is the current condition of the differentials, is this a high mileage vehicle.
If no, you can just swap everything over; if yes, that's when you start thinking about new bearings, seals, etc..
