Wiper failure
12 Aug 2026 17:20 - 12 Aug 2026 17:20 #265089
by Sondre
Wiper failure was created by Sondre
Hello
I have a sporadic problem with the windshield wipers.
When I turn them on intermittent, they work fine, but suddenly the relay starts clicking rapidly for 1-2 seconds. Then the wipers resume their regular movement. It's like the relay doesn't stay on, and after 1-2 seconds of clicking, it catches on and the wipers work as normal. It can happen every 3 to 20 times the wipers make a round.
The problem can also occur when I switch them on low or high.
2002 jimny
Any thoughts here?
Cheers, Sondre
Wiring diagram: page 48
2002 jimny
Any thoughts here?
Cheers, Sondre
Last edit: 12 Aug 2026 17:20 by Sondre.
- The Coil Spring
- Senior Member
- Thank you received: 6
24 Aug 2026 10:44 #265151
by The Coil Spring
Replied by The Coil Spring on topic Wiper failure
Sporadic problems are often caused by corrosion around the wires' ground points, also called earth.
Have you tried with a new relay?
Time to create page: 0.158 seconds
