Jacking points, sorry 🙄
22 Jun 2026 13:41 #264734 by muttsnut
 Hello, im sorry as this topic probably comes up a lot, but i couldnt find anything specifically for this stubby tube!
Can this be used as a jacking or support point? It would be so handy if it could. It seems to be reinforced behind, although the tube is relatively thin!
Brent
22 Jun 2026 14:00 #264735 by fordem
Replied by fordem on topic Jacking points, sorry 🙄
The recommended jacking points are in the owner's manual.
For the "emergency service" jack, they are on the radius arms, you'll find a small protrusion on the underside about halfway down the length.
If you're using a floor jack, you can jack under the axles.
For a two post hoist, you can lift under the radius arm pivots.
To answer your specific question - use at your own risk, personally I wouldn't.
23 Jun 2026 11:56 #264740 by muttsnut
Replied by muttsnut on topic Jacking points, sorry 🙄
Ill stay clear. Pity because they are handy location.
Thank you.
