Retro fitting OEM roof rails to non-UK car.
08 Jun 2026 15:02 #264633
by FOSTER_T
Retro fitting OEM roof rails to non-UK car. was created by FOSTER_T
Hi all, I'm after some guidance here please. I'm looking to install some OEM style roof rails on my 2013 Jimny which has just arrived from Japan and as such doesn't have any rails (nor mounting points)
Anyone done this before?
It's pretty clear I'll need to drill some holes and seal against rain etc... But what goes on the inside? Does the UK spec cars have some kind of doubler plate or spreader plate on the inside? The roof is curved at that point so I don't fancy just tightening up bolts.
And does the whole roof lining need to come out?
Any advice/info that would take out the guess work, much appreciated. Thanks in advance.
- Thank you received: 1999
08 Jun 2026 15:48 #264634
Replied by Lambert on topic Retro fitting OEM roof rails to non-UK car.
As standard a uk jimny uses captive studs that protrude through the roof. Replicating them isn't the work of 5 minutes. If you are just wanting to carry stuff have a look in Japanese sites for clamp on cross bars. If you just want the longitudinal rails maybe consider adhesive? Either way have a search as there was a similar question asked within the last few months.
08 Jun 2026 19:05 #264637
by FOSTER_T
Replied by FOSTER_T on topic Retro fitting OEM roof rails to non-UK car.
Thanks for the info.
Yes I spotted a recent thread with a similar theme - I think that guy was after an aftermarket rack though (which I agree would be logical) but I want to OEM rails.
I could do with seeing the inside of an original roof skin minus the headlining - that would answer most my questions I reckon.
08 Jun 2026 20:00 #264638
by Busta
Replied by Busta on topic Retro fitting OEM roof rails to non-UK car.
I don't have any pictures, but the studs are welded onto a curved reinforcing plate which is welded to the roof. What sort of thing are you wanting to carry on the roof?
09 Jun 2026 03:22 #264639
09 Jun 2026 06:01 - 09 Jun 2026 06:03 #264640
Replied by yakuza on topic Retro fitting OEM roof rails to non-UK car.
I had sort of the same issue when mounting the wrong back seat in my car. no mounting points for the fold up seat bottoms in my 2005 jimny.
So I put riv nuts there and all good now.
They can also be used in the roof but they should be of a more solid version than my weak ebay ones. And there should be a reinforcement plate ore something on the inside of the roof sheet metal to take the forces from wind and roof load.
this one is similar to my weak version:
www.halfords.com/tools/garage-equipment/...t-rivets-808046.html
Here in Norway the professional version cost like 250 GBP but the Vevor one looked OK:
eur.vevor.com/rivet-nut-tool-c_12215/vev...oNiVZEcaAhiVEALw_wcB
Very useful tool imo.
Even though I have the weker version it have been used alot so allmost out of rivnuts and the "pliers" are beginning to give in.
Last edit: 09 Jun 2026 06:03 by yakuza.
Time to create page: 0.442 seconds
