G13BB Water Inlet Hose Replacement
25 May 2026 23:19 #264503 by Crankshaft Culture
I'm replacing the old coolant hoses on my 1998 Suzuki Jimny Wide (JDM 1.3 G13BB). Upper and lower rad hoses are done, but I figured I'd replace the "water inlet hose" while the coolant is drained. I cannot figure a good way to access the hose clamps (the spring kind) and get a good grip on this hose. The hose has the OEM part number 1785281A00 and is highlighted in green.
I can't imagine I'd need to pull the intake manifold off to access it. Any tips, or am I just in for more Jimny Gymnastics contorting myself to reach? :)
26 May 2026 19:37 #264519 by yakuza
Long nose angled pliers?
Very useful tool!
27 May 2026 13:54 #264530 by fordem
Do a Google search for "flexible hose clamp pliers".
The following user(s) said Thank You: Crankshaft Culture
29 May 2026 20:52 #264556 by Crankshaft Culture
I did get a set, and they allowed me to get the top hose clamp off. The lower one is turned so the part you squeeze is facing the block. I may just use a Dremel and cut the darn clamp off and go get new ones that screw on. The lower is impossible!
Time to create page: 0.215 seconds
