Bent Outer Tie Rod
05 May 2026 10:44 #264372 by major clanger
Replied by major clanger on topic Bent Outer Tie Rod
I don't bother with an alignment on anything with a rigid rear axle. There is a simple method to get the toe correct using a laser level, straight edge across the rear wheel then steel measure between front wheel and laser beam. There are several YouT vids showing the details.
Used this method on a Defender then went on and used it on anything with fixed rear 0 degree geometry; Fiat Panda, Coupe, Honda Jazz, no problem whatsoever.
Time to create page: 0.173 seconds
