2 questions about rear prop shaft
- The Coil Spring
- Senior Member
- Thank you received: 6
13 Apr 2026 14:49 #264230
by The Coil Spring
2 questions about rear prop shaft was created by The Coil Spring
I need to replace the rear universal joint.
- Will oil leak out of the transfer case when rear prop shaft is removed?
- Am I allowed to drive the Jimny in 4WD without the rear prop shaft fitted?
- Thank you received: 1988
13 Apr 2026 16:29 #264231
Replied by Lambert on topic 2 questions about rear prop shaft
If you are just removing the propshaft then you will be ok unless you also remove the output flange
Yeah it will do fwd ok too.
The following user(s) said Thank You: The Coil Spring
14 Apr 2026 08:36 #264235
by facade
Replied by facade on topic 2 questions about rear prop shaft
No oil comes out of the transfer box.
The car will drive fine in 4WD using just the front axle, but I wouldn't drive it on the road like that, if there was an accident even the least observant of inspectors will notice the missing propshaft and your insurer will try and blame it for the accident. Even if they can't they will play the "undeclared modification" card to reduce the payout, or even declare the insurance void as they would never cover a FWD jimny.
Why do you need to?
With the propshaft off half an hour will see a new spider fitted then you can just put it back.
Why do you need to?
- The Coil Spring
- Senior Member
14 Apr 2026 16:58 #264237
by The Coil Spring
Replied by The Coil Spring on topic 2 questions about rear prop shaft
Only to move it out of the way when needed. Not going for a drive.Why do you need to?
Time to create page: 0.203 seconds
