4" lift kit.
28 Mar 2026 21:10 #264144 by siggibl
4" lift kit. was created by siggibl
Hello
I have a Suzuki jimny 2019 with a 4" lift kit from jimnybits. Am running on a 33" tiers.
After the upgrade I hear a ratteling sound in 4x4 mode when I drop the throttle on a 60 km.
Dos any body know that that is, in 2x4 I dont hear any sound.
best regards
siggi
29 Mar 2026 05:37 #264145 by Lambert
Replied by Lambert on topic 4" lift kit.
My immediate question would be did you buy and fit the complete kit with the cross member relocation so as to give clearance for the front propshaft?
29 Mar 2026 08:11 #264146 by DrRobin
Replied by DrRobin on topic 4" lift kit.
Is that 60Km/hr on tarmac?
Jimnybits seem to do more than one 4” lift kit, could you let us know which one, what it included and who installed it?
29 Mar 2026 12:23 #264147 by siggibl
Replied by siggibl on topic 4" lift kit.
Hello
Thanks for reply
This is the kit that I did buy 4" / 100mm Suzuki Jimny Black Raptor Premium Full Suspension Lift Kit - 2019 On
www.jimnybits.com/4-100mm-suzuki-jimny-b...ift-kit-2019-on.html
I did install this on a manual transmission car. The only thing that comes to mind is the chane in the transfer box
I will open it next week to install lower gears into it.
29 Mar 2026 14:27 #264148 by Lambert
The chain is driving all the time regardless of 4x2 or 4x4 or 4x4 low so I would expect if it were the chain it would be constant. It could be a drive shaft joint on it's way out?
29 Mar 2026 15:06 #264150 by siggibl
Hello
No the drive shaft is not all the way out, I did put 2.5 cm spacer on the drive shaft in the front.
So it should be ok,
This did come with the kit.
best regards
siggi
Time to create page: 0.204 seconds
