JB64W Parts Availability
24 Mar 2026 04:42 #264082
by JB64W
JB64W Parts Availability was created by JB64W
Hi,
I have a SUZUKI Jimny 2019 3BA-JB64W import and chasing parts here in Australia and need a CAM chain and turbo charger. OEM Part for turbo charger is 1390077R50.
So far I have found no available parts for this model due to it limited import as its meant for only the Japanese market. It has the R06A 660CC turbo engine.
cheers
cheers
- Roger Fairclough
- Thank you received: 225
24 Mar 2026 10:12 #264087
by Roger Fairclough
Replied by Roger Fairclough on topic JB64W Parts Availability
I believe it was meant for the Japanese market to overcome taxation problems, so it may be possible to replace the turbo engine with a suitable engine from a donor Suzuki one.
Just a thought.
Roger
Just a thought.
Roger
24 Mar 2026 12:48 #264089
by fordem
You'd also need to consider the "mixing & matching" of the electronics, the 3 cylinder ECU won't run the 4 cylinder engine, so you'll need to get the 4 cylinder ECU to "play nice" with the remainder of the electronics, not insurmountable, but also not a simple task.
Replied by fordem on topic JB64W Parts Availability
I suspect there will be a significant difference in gearing.Just a thought.
24 Mar 2026 14:09 #264092
by Motacilla
Replied by Motacilla on topic JB64W Parts Availability
It needs a cam chain and turbo already? What did you do to that poor little car???
I'm on the wrong side of the world to have experience with kei Jimnys, but if it were me, I would just order the parts from a Japanese seller.
I've dealt with Japanese parties on car bits before, and they have been always very helpful and reliable. Shipping for small parts is fairly trivial, though of course you must account for customs cost. Google Translate is your friend here.
Just a thought. Good luck.
24 Mar 2026 14:38 #264096
by fordem
The turbocharger is available from megazip.net - 13900-77R50 has been discontinued and the replacement is 13900-77R52.
You can also try partsouq.com & amayama.com
01 Apr 2026 23:48 #264176
by JB64W
Replied by JB64W on topic JB64W Parts Availability
Thanks Roger and yes my research tells the same. Its a JDM issue for Japanese Domestic Market. KEI light vehicle so it all makes sense.
Time to create page: 0.398 seconds
