Random Revving
09 Mar 2026 11:53 #263943
by Spiteri
Random Revving was created by Spiteri
Hello,
I have a Suzuki Jimny 1998, recently it is revving up to 1500 rpm and it some times drops the revs almost turning off but then it stabilizes immediately. I noticed it happening when it starts to warm up, because in the morning it does not do it but after driving for a bit it starts to rev, even whilst driving I go to change gears and when I press the clutch it stays revved until I put in gear and it is normal. Whilst in traffic it revs up, stabilizes and sometimes drops the revs and stabilizes again. I took it to my mechanic and he cleaned the throttle body and idle sensor and it still did it.
Is there some one who maybe experienced the same issue or know what I need to do next.
Thank you in advance,
Cain Spiteri
Cain Spiteri
- major clanger
- Junior Member
- Thank you received: 7
09 Mar 2026 12:42 #263944
by major clanger
Replied by major clanger on topic Random Revving
Whilst I do not own a Jimny of that generation I do own another vehicle of that same year. Vehicles of that period use an 'idle control valve' to manage idle speed during warm up and under various load conditions rather than just a throttle body managed by the ECU as we have now. It is a physically separate valve from the throttle body
A common problem is that this valve often just needs a clean or its seals have developed an air leak. What you describe sounds just like a dirty (possibly faulty) idle control valve. The mechanic might have cleaned the throttle body but did he clean the idle control valve? If it was me I would remove it, clean and replace the seals.
09 Mar 2026 13:11 #263945
by Spiteri
Replied by Spiteri on topic Random Revving
Thank you. Yes he in fact took it all out and cleaned it we were actually surprised that it started to rev again. I will be taking it again to see maybe it needs to be replaced (Idle control Valve) but we'll see. After 28 years it is expected that I have to start replacing some come parts.
- Thank you received: 2006
09 Mar 2026 13:13 #263946
Replied by Lambert on topic Random Revving
There's a little impeller type thing in the edge of the throttle body in a chamber that bypasses the butterfly plate in the air stream that drives a hall effect sensor. They get sticky and don't run freely which confuses the ecu.
- Thank you received: 679
09 Mar 2026 13:30 #263948
Replied by DrRobin on topic Random Revving
I don’t know if this engine has a MAF sensor, but a dirty sensor or one on the way out can cause ‘hunting’ at tick over.
My first guess would be throttle body (as Lambert suggested) but if that fails to fix the problem then it might be a MAF sensor, if it has one.
Does you car have AC? When AC is engaged it lifts the revs at tick over to overcome the increased load. If the AC is getting triggered, but no AC in use that might do it.
10 Mar 2026 12:57 #263953
by CB1289
Replied by CB1289 on topic Random Revving
Hi bud - I've got a 2001 which was doing something similar. I bought a throttle body off eBay which included idle air control valve etc and I just fitted that.
It seems to have done the trick for me! I think there were 2 available so I expect that the other one may be available still. It was Lambert's engineering I think - I bought off their eBay store and it cost about £70 from memory.
Time to create page: 0.173 seconds
