Cold start ticking noise – G13BB
14 Feb 2026 01:14 #263757
by jimu
Cold start ticking noise – G13BB was created by jimu
Hi everyone,I own a Suzuki Jimny JB33 with the G13BB 1.3 engine.I’ve recently noticed a ticking noise when the engine is cold. The sound is clearly audible at idle right after startup, but after driving for about 5–10 minutes and once the engine warms up, the noise reduces significantly.
Has anyone experienced something similar with the G13BB?Is this common with age, or should I be concerned?Thanks in advance!
14 Feb 2026 01:27 #263758
by jimu
Replied by jimu on topic Cold start ticking noise – G13BB
here’s the sound I’m talking about
14 Feb 2026 06:20 #263759
Replied by yakuza on topic Cold start ticking noise – G13BB
How cold?
Mine is ok as long as it is above zero but minus sets off alot of noise.
Long since the last Oil change?
Bad or wrong oil, or a bad or small Oil filter Could make the time it take to get up to working temp longer.
I would first change the Oil and filter. See spec in the wiki section.
To find where noise come from a car stethoscope is excellent.
Could also use a piece of wood to press on to engine parts and listen to the other End of it.
The following user(s) said Thank You: jimu
14 Feb 2026 19:28 #263762
by jimu
The minimum temperature here is about 10°C. Recently I changed the oil and the filters as per the maintenance manual.
Time to create page: 0.092 seconds
