Problem with fuel injector nozzle model [Jimny M13A 2000]
- luancampos
05 Jan 2026 13:41 - 05 Jan 2026 13:41 #263276
by luancampos
I have a 2000/2001 Jimny M13A - SN413V and I have a problem I can't solve: the fuel injectors are purple Denso injectors with code 3980, smaller than usual, even though the original code is 15710-80G00. I bought new injectors, but they are a little longer than the ones in the car and I can't find replacements to buy.
The image below shows this difference. On the left is the original injector from my vehicle and on the right is what should be the new replacement, but it is longer. The injectors are bad and I need to replace them. I even bought another fuel rail of a newer Jimny model, but using the new or old fuel rail, it was the same, fuel leaked. (they seem tight or out of position).
What should I do? Please help me.
Last edit: 05 Jan 2026 13:41 by luancampos.
05 Jan 2026 17:13 - 05 Jan 2026 17:14 #263284
by fordem
Replied by fordem on topic Problem with fuel injector nozzle model [Jimny M13A 2000]
First question - are you sure your vehicle is an SN413V?
Second question - where/how did you get the part number?
Looking at Suzuki's WWEPC, an SN413V would/should have a G-series engine, not an M-series, and the part number for the injector is different.
Last edit: 05 Jan 2026 17:14 by fordem. Reason: formatting
06 Jan 2026 00:22 - 06 Jan 2026 00:26 #263290
Replied by yakuza on topic Problem with fuel injector nozzle model [Jimny M13A 2000]
The shorter injector Does not look like a G16 injector. Havent seen the G13 ones, sorry.
Edit : google says your injector on the left is a G13
The longer New one look like a m13 and other m-series injector.
Picture of your engine would be nice now.
Last edit: 06 Jan 2026 00:26 by yakuza.
- luancampos
06 Jan 2026 11:20 #263295
by luancampos
Replied by luancampos on topic Problem with fuel injector nozzle model [Jimny M13A 2000]
Believe me, my vehicle has an M13A engine. It has a license plate, labels, the VIN code confirms it, and the frame is from this series. I know how to differentiate the engines. My vehicle is an SN413V TYPE2 according to VIN research, JLX. What I've noticed is that searching for photos of my original injector, there are very few available, it seems like a rare find. I've concluded that it seems to be a limited transitional model for the Jimny. The injectors that appear identical to mine refer to Ignis, as below:
izap24.ru/tovar/31784223_forsunka-topliv...-2001-150323980.html
- CelicaRacer
- Senior Member
- Thank you received: 15
06 Jan 2026 11:45 #263296
by CelicaRacer
1999 Suzuki Jimny
1990 Toyota Celica garage queen
1996 BMW e36 touring track car
2007 BMW e61 520d touring
1998 BMW Z3 Drift Car
Replied by CelicaRacer on topic Problem with fuel injector nozzle model [Jimny M13A 2000]
the original injectors are bad but not leaking or both new and old are leaking?
1999 Suzuki Jimny
- luancampos
06 Jan 2026 11:53 #263297
by luancampos
The old fuel injectors that came with the vehicle are outdated and I haven't had them for years. At the time, I managed to find the only compatible size, a shorter one, part number 15710-52G00, which is for a Suzuki Metro or Swift, if I'm not mistaken. However, I'm having problems (high injection time around 3.7 to 4.0ms) that indicate the injectors are the issue; they don't even seem to have the same parameters as the original (flow rate), so I need to replace them.
Time to create page: 0.263 seconds
