Radiator drain plug
24 Nov 2025 11:13 #262892
by Sy
Radiator drain plug was created by Sy
Good morning. I've nearly got my Jimny back together again after replacing the head gasket but im missing the radiator drain plug. Its a Nissens 64162 radiator. Does anyone know where I can get a new drain plug from please?
Thanks
Simon
Thanks
Simon
- Thank you received: 2005
24 Nov 2025 11:32 #262893
Replied by Lambert on topic Radiator drain plug
From memory I don't remember the nissen one i had being compatible with the factory suzuki one so it might be a matter of seeing if the local motor factor is able to get one as a separate part though i wouldn't put much money on that.
24 Nov 2025 11:42 #262895
by Sy
Replied by Sy on topic Radiator drain plug
Thanks for that. I've emailed Nissens so I'll see what happens there and ill try a local parts place.
24 Nov 2025 12:10 #262896
by Sy
Nissens got back to me to say the part is not available separately. Grr!
Anyone tried blanking the drain off in a DIY way?
25 Nov 2025 06:50 - 25 Nov 2025 06:54 #262899
Replied by yakuza on topic Radiator drain plug
did you get the thread dimension?
uk.misumi-ec.com/vona2/detail/2213035638...raH27tMaAk8AEALw_wcB
Also ebay is full of plugs. even UK sellers.
But most plumbers got these or something that would fit as long as the threads are a common type.
Last edit: 25 Nov 2025 06:54 by yakuza.
25 Nov 2025 10:15 #262900
by Sy
Update from Nissens. They have found me a plug and are going to send it free of charge today.
Time to create page: 0.171 seconds
