Clarification on manual hubs
- MrandMrsHart
- Thank you received: 6
18 Nov 2025 20:50 #262811
by MrandMrsHart
Clarification on manual hubs was created by MrandMrsHart
Hi all
please can i get some clarification on manual hubs because after learning about them today i have found myself down a rabbit hole with the article on the wiki and youtube videos and still confused.
this morning before uni i did my 2 inch suspension lift. I noticed when doing the fronts that the two metal pipes leading to two braided lines attached to the hubs were practically none existent. They have completed rotten away in places. Now i havent had to use 4 wheel drive yet so not sure if a light would come in or not but whilst researching what these pipes where that ran along the to of the front diff i found put that they are vacuum for the hub 4 wheel drive system.
Knowing that i will have to do something about it before taking the jimny out in the mud i came across all the info on manual hubs.
so am i right in thinking that basically on the transfer leaver (2003 car so not a switch). With them in the unlocked position both 2WD-H and 4WD-H are 2WD-H and 4WD-L becomes 2WD-L and in the locked position 2WD-H is 2WD-H, 4WD-H is 4WD-H and 4WD-L is 4WD-L
does that make sense and have i got it right?
I feel stupid for asking but my brain is working only in one way about this
TIA
TIA
18 Nov 2025 21:39 #262812
by 300bhpton
Replied by 300bhpton on topic Clarification on manual hubs
With the hubs unlocked, putting the transfer case into 4wd will only make the front prop spin, it won't drive the front wheels. Low or High makes no odds for this.
To engage the front wheels, you'll need to lock the hubs as well.
TBH, unless you have a very specific use case, I don't see why anyone would want manual hubs. Very 1950's.... tech.
There really are only minimal gains to be had by unlocking them. And who buys an off road Jimny for mpg reasons?
Plus, I don't understand why you'd want a 4wd system that requires you to do something in the cabin, then park up and get out and mess about in the mud on both sides of the vehicle, just to use 4 wheel drive.
I haven't checked prices, but surely replacing/fixing some vacuum lines must be way cheaper and a lot less labour than going for manual hubs?
18 Nov 2025 23:58 #262815
Replied by yakuza on topic Clarification on manual hubs
Thanks for defending the vacuum hubs!
My SJ got straight solid hubs locked. Havent bothered to put manual hubs there even though there is a few sets in stock.
I like my vacuum hubs, fixed them too.
I am forming the vacuum-party!
Open for all vacuum users anyone with hubs can join, but no pressure!
The Vacuum Party.
- it sucks
The Vacuum Party.
- it sucks
- Thank you received: 1998
19 Nov 2025 08:19 #262818
Replied by Lambert on topic Clarification on manual hubs
Manual hubs have a place. I rely on them because I do a lot of low speed work where traction in not an issue and running in 4lo would cause windup. As for everyone saying it's a pain getting in and out of the car every time you need 4x4 that's a none argument as for example this morning it was snowing when I went to work so as I'm cleaning the snow off and checking the rest of the car I just switch the hubs in an then leave them. I still control the selection of drive from inside the car and as it happened 2wd was fine but I will leave the hubs in until the forecast clears even if that's tomorrow. It's going to be an infinitely small chance that you are suddenly going to go from tarmac to axle deep mud or snow or whatever without some prior warning, it just takes a little bit of thought. All I'm doing is having the 4x4 single isolated instead of double isolated with the vacuum hubs so th wheels are pushing the front half of the drive fine instead of it just sitting there. It's really nt as archaic as some people want to portray it.
19 Nov 2025 09:40 #262822
by 300bhpton
Lambert, I think you qualify for the "specific use case" as you use low range to move trailers about.
Very sensible thing.
Although ultimately manual hubs are a work around for the Jimny not having a centre differential to enable low range on sealed/hard surfaces.
You wouldn't believe the number of times I've seen a Series Land Rover stuck off road with only the rear wheels being driven.... because the driver forgot to get out and engage the hubs too.
I don't have any experience with Jimny manual hubs, but in the Land Rover World they are all aftermarket as LR never fitted them from the factory. Most makes have reputations for leaking oil and/or failing.
19 Nov 2025 09:57 #262825
I have had 2 sets of AVM ones on 3 cars with over 175000 miles on them and the only reason the first set failed was a lack of maintenance through ignorance. I fully expect this current set to see my 2024 into the crusher.
The following user(s) said Thank You: 300bhpton
Time to create page: 0.174 seconds
