What manual gear boxes are the same?
13 Nov 2025 03:40 #262701
by Noahmills
What manual gear boxes are the same? was created by Noahmills
Hello everyone, I have a manual 2005 vvt facelift Jimny (with the push button transfer case) and was wondering if a 2012 manual transmission would bolt straight in and work the same? My gear box has got a really bad whine and is about to blow haha, don’t want to repair the box as it has done almost 400000kms
- Thank you received: 1999
13 Nov 2025 04:21 #262702
Replied by Lambert on topic What manual gear boxes are the same?
Yeah that 2012 will work.
The following user(s) said Thank You: Noahmills
13 Nov 2025 06:29 - 13 Nov 2025 06:34 #262704
Replied by yakuza on topic What manual gear boxes are the same?
My 05 jimny have the 2012-ish gearbox now. bought and replaced some years ago and ran ok for a few years until I changed the bearings two months ago.
The 2012 gearbox will most likely have more of the upgrade bearings with closed sides and should last longer.
Rough guide but might vary with markets:
98 to 00 r7me with the flange for the G13
01 to 04 r7me with flange for the m13
05 to 09-ish R72 with open bearings different ratio gears so will not fit earlier.
10 to 18 R72 with closed bearings. same ratio gears as above.
Last edit: 13 Nov 2025 06:34 by yakuza.
- Darthblaker7474
- Elite Member
- Thank you received: 37
13 Nov 2025 20:34 #262727
by Darthblaker7474
Replied by Darthblaker7474 on topic What manual gear boxes are the same?
Can confirm, I have a 2016 gearbox in my '08.
It was cheaper than getting my one refurbed, £500 incl. fitting!
Time to create page: 0.242 seconds
