MPH speedo conversion?
03 Sep 2025 06:16 #261829 by FrankFisher99
Hi all, I'm picking up a fresh 2010 JB43 import from Japan this week and will be converting the speedo from KPH to MPH; has anyone done this? I've located the right instruments/dials from Lockwood, but I'm wondering how the needles come off on this Gen3 model - lever them off, or wind them anti clockwise? Does anyone know with certainty?
03 Sep 2025 07:39 #261830 by yakuza
Replied by yakuza on topic MPH speedo conversion?
pulled carefully straight off.
I put mine back in a bit off so getting a nice and cold engine and can drive longer on the empty fuel tank :)
make a note/line/tape to mark the correct positions before you dismantle.
the speedo I put back in more correctly I think, getting correct redout there.
I did not convert, just searching for an error inside there but changed the complete cluster in the end.
If you change the cluster the milage/kms will be altered, it is stored in the cluster and not the ECU.
03 Sep 2025 15:24 #261832 by FrankFisher99
Thanks! Im really worried about breaking them, so when you say "pulled straight off" could you just describe exactly what you did? Please? Also, what year car do you have?
03 Sep 2025 16:49 #261833 by fordem
Replied by fordem on topic MPH speedo conversion?
Slide a dining fork under the needle so that the tines of the fork sit under the boss on either side of the shaft, slip a paper napkin between the back of the fork & the dial to reduce the chance of marring the old dial, and gently ease the needle up and off the shaft.
03 Sep 2025 16:54 #261834 by yakuza
But very gently.
05 Sep 2025 07:39 - 05 Sep 2025 07:40 #261845 by facade
Replied by facade on topic MPH speedo conversion?
In The Olden Days the works used to be held onto the face with 2 screws. then you used two spoons (nowadays every one has those trim tool levers) to pull opposite sides up at once against those screws, so the pivot shaft didn't bend.
Be careful that you are pulling it off square.
Again, in The Olden Days, when the speedo worked magnetically against a spring, the rest position of the needle was marked on the dial- you had to push the zero stop down and it came to rest well below zero.
Nowadays the speedo is a stepper motor, most likely you connect the dash without the needle, power it on so the motor sweeps and goes back to zero, then put the needle on at zero.
Last edit: 05 Sep 2025 07:40 by facade.
